Seeking Advice on SC400 misfiring problem.. Codes 13, 14, 24, 31.
Old 08-14-08, 11:22 PM
1JZ/240sx
1JZ/240sx's Avatar
Unhappy SC400 misfiring.. Codes 13, 14, 24, 31.
Well, I was recently driving my car and all of a sudden the engine started to missfire and run as if half of the cylnders died.
So I did the self diagnostics and thiese are the codes i received.
13- RPM Signal Curcuit
14- Igniter Signal
24- Intake temp sensor curcuit
31- Low air flow meter voltage
FYI: plugs, plug wires, distributor cap & rotors had been replaced prior to this problem.
So i borrowed a friends MAF, bought 2 new ignition coils and replaced them, but still not firing.
tried resetting ecu to see if i got any different codes or difference in idle.
No luck.
Is there anything that I may have overlooked, or misunderstood from the codes?
Thanks in advance for any insght
-Gary
Old 08-15-08, 11:42 AM
1JZ/240sx
1JZ/240sx's Avatar
..................please?
Old 08-15-08, 12:25 PM
TheMole
TheMole's Avatar
If it happened right after you did the maintenance items, try rechecking your installation. Double check all the connections especially the distributor wires, cap, rotor...
Old 08-15-08, 03:20 PM
1JZ/240sx
1JZ/240sx's Avatar
no but
it happened immediatly after installing a new a/c compressor.
The car idled fine while the compressor charged. for roughly 30 min. I did not test drive it that nite.
The next day got in and drove about 1 mile and the power died
not sure what that could do, but you never know..
I also only swapped out the MAF sensor. i did not swap the whole housing
all of the above maint was done at least 600 miles ago.
Old 08-15-08, 05:40 PM
TheMole
TheMole's Avatar
You have to disconnect some hoses/plugs to get to the ac compressor correct? Double check all of those connections. Seems like a loose connection to me.
Old 09-16-21, 01:38 PM
vipallday
vipallday's Avatar
Default Did you ever fix this… even thought it’s 13 years later lol
14- Igniter Signal
No luck.
-Gary
okay so did you ever fix this and how because I having same problem but I never messed with the ac mine works fine
Shajay69 (11-21-21)
Kingunis
12-12-15 12:24 PM
user762198
12-29-09 04:30 AM
QwkSC
07-04-09 08:35 PM
KrazeMatik
04-06-09 12:26 AM
BoNgBlAzE
11-23-08 12:32 AM
Quick Reply: Seeking Advice on SC400 misfiring problem.. Codes 13, 14, 24, 31.
