2jzgte with R154 auto to manual swap question
Hello,
Does anyone know how to bypass the neutral safety switch? I know this has been asked before, and addressed on some applications. I've seen explanations mainly on auto to manual conversions retaining the automatic wiring harness. On that, the plug for the neutral safety switch is near the transmission which is easily found. On persons doing a manual to manual swap (e.g. w58 to r154) The plug is located on the switch near the clutch pedal.
But I am doing an auto to manual swap with a manual transmission harness. Hence.. there is no safety switch on the harness itself, nor is there one (unless someone can find it because I have looked) near the driverside foot well.
Any Ideas on how to bypass the safety "switch"? I've thought of the idea of grounding it on the ecu sid, but how do I go about doing that?
Thanks in advance!
Thanks in advance!
if its a manual engine harness and you still have a auto dash harness then that plug will not be there. one way is to hotwire it and make a push button start. there are some threads on that. but otherwise i think you would need to replace the inside dash harness that has that plug that goes to the clutch pedal for the clutch start switch
Ok, so Lexus FTW has told me to run a wire from EB1-3 to the black with white stripe wire of 76(NSW) running to the ecu. At first I tried to do this, but I found out that the #76(NSW) wire did not exist on my ecu plug!!!..... It existed in lexus ftw's plug.. It exists in all the pinout diagrams that I have of both the jdm and usdm ecus..
Basically. IT SHOULD BE THERE. Instead, there was a little yellow plug signifying that the pin was not used. So I grabbed a pin out of my GE harness, installed it where the #76 (NSW) should be, connected this wire to EB1-3 and STILL... No click of the starter.. No nothing.
I feel like I'm at the end of my rope. I need help from a wiring guru asap.
BTW for reference I have a mines chipped ecu. From a 93 JDM 6sp supra.
Definately need all the help I could get.
there is a wire under your steering colum that comes from your ignition switch meter to figure out which one sends power when you turn the key for start. then attach wire there and run through fire wall to your starter relay directly and your car will function normally. there is a thread on here about this however it addresses the prob when you have a manual with an auto ecu, i think this fix would give you the same bypass even though this is a diff issue. cant hurt trying.
Ok, So while I was really frustrated at first that the car would not crank, I forgot to take note that other things did not work.
First the fuel pump isn't priming.
Also, can anyone tell me which pin on the ecu is supposed to give it power so I can check and see if it is getting power?
I am debating on where to start if the ecu is not getting power like it should.
sniper
Performance & Maintenance
02-02-05 02:02 PM
