how to get the specs for a turbo?
Old 08-17-08, 06:29 PM
SC300_704
SC300_704's Avatar
Default how to get the specs for a turbo?
i got a turbonetics turbo that i bought locally that supposed to be a 60-1 but on the compressor and hot side it doesn't have a/r numbers on it like other turbos, what am i supposed to do to get the spec info on it? it has a 2.75" inlet, 2" outlet and 3" outlet on the hotside...
Old 09-08-08, 02:33 PM
SC300_704
SC300_704's Avatar
bump..still need help on this...
Old 09-09-08, 10:10 AM
2jzlex
2jzlex's Avatar
Ask here, http://forum.clubna-t.com/ you'll get every answer you want.
Old 09-09-08, 12:55 PM
SC300_704
SC300_704's Avatar
i'm already a member on ClubNa-t and a lot of people in that forum is also in CL so i thought someone here might know as well...
Old 09-09-08, 02:25 PM
2jzlex
2jzlex's Avatar
Yeah, the handful of people that can actually answer that question that are members of CL spend the majority of their time on NA-T cuz CL is so freakin weak. But to save you some time, get yourself a micrometer and measure the diameters of the small part of the front compressor wheel and also the larger part, do the same with the turbine wheel.
Jon
Old 09-09-08, 02:59 PM
SC300_704
SC300_704's Avatar
so you're saying take the housings off then measure from top to bottom of the wheel/turbine?
Old 09-09-08, 03:08 PM
LexusFTW
LexusFTW's Avatar
+1 2jzlex
http://www.turboneticsownersclub.com...opic.php?t=882
Old 09-09-08, 03:41 PM
SC300_704
SC300_704's Avatar
Originally Posted by LexusFTW
oh man, thank you so much LexusFTW..that helped me out a lot..i guess mines really a TO4B since it's the only compressor that has a 2.75’’ inlet ..and as for the ball bearing part, he didn't say anything about having a coolant cooled on the turbo..but mines not a bb like i was told..i don't see the shiny ***** from the oil drained hole like what the guy explained....
PoGikoSc4
12
09-08-11 11:23 PM
JacobT
10-13-07 01:11 PM
JTJerryls400
07-26-05 07:45 AM
indypwr
02-24-04 08:45 AM
Quick Reply: how to get the specs for a turbo?
