Maintenace or hanging myself hmmmmm?
Well I have to change the starter on my car (SC400) cause it is getting pretty worn. I get the old * click * no start 5- 10 times before the car actually starts on some days. So I figured with that whole job ahead of me I'd might as well replace a bunch of crap. my list so far is
all manifold gaskets
spark plugs
wires
electric fan conversion
My question is with the high miles i am considering doing the timing belt as well since the radiator will be out and the cooling system will be drained. Is timing belt a reidculous job. I mean i have done cam sawps on LS1's and stuff but I wouldn't consider myself a pro mechanic.
spark plugs
wires
Ok I have a question. The tutorial on Lextreme says you don't have to remove the injectors then later in the tutorial is tells you to remove injectors. I would like to know if you have to cause I want to have all my gaskets and o-rings ready, rather than running back and forth to the lexus dealer
Also anyone who has done this before know exactly what gaskets i will need?
so far:
Throttle body
rear water neck
upper intake manifold
lower intake manifold
so far:
Throttle body
rear water neck
Replace your water pump if you're doing the timing belt. If you're a non VVTI it should be slightly easier than vvti I changed my timing belt, water pump about two months ago. I highly recommend a vehicle repair book if you don't have one, but it's not that hard. Took me a little longer than expected because of Florida thunderstorms every day =(
well I began the starter adventure tonight. I think the biggest pain is still ahead. It took me 1.5 hours to remove everything down to the lower intake manifold. I gave up at the gas lines for tonight as the engine still had some warmth to it. I'll tackle the rest of that crap tomorrow.
The upper intake manifold to lower intake manifold gaskets look to be in very goos shape. Anyone ever reuse these?
might have to do this soon as well.
Might as well. I did replace them. You can see my starter thread here.
https://www.clublexus.com/forums/sho...d.php?t=348391
Thats is going to be all I'll need though. All my tubing is in excellent shape. I am amazed how clean my engine is. Maybe one or two rusty bolts, Zero seized or rounded bolts.
top manifold off
Two more hours in and i hit a wall. See the water neck in the back. There is a hard copper line bolted to the back of that waterneck about an inch from the fire wall with the bolts facing down at a 45* angle. Tomorrow i am hoping that a flex head ratcheting wrench can reach those. Once those are gone I remove the water neck and then its on to the starter.
