My JDM 2JZ-GTE Supra Engine Conversion
#91
I just drop my engine in yesterday. Much Much harder than putting in the 2jzgte than the 2jzge It's hard to reach the engine mount bolts and the rear of the turbo kept hitting the fire wall. I needed to angle it just right and use the jack to lift the transmission up to line up the engine mounts. I think that putting in the harness with the engine out would make for a much easy install because the harness has to run under intake manifold. There are ground points and plugs that need to be attached. It's hard to see and reach. There is limited space to work with the engine in. I am glad that I just waited to install the engine and harness as one.
https://www.clublexus.com/forums/sho...=374945&page=3
#94
#95
lol, true uhh well he sent me a message today...
so i set up a thing with him to do 2 payments of 60 since my bank is drained to .42 cents to my name.
Which really sucks since i am gonna be starting collage in January and work had a huge hour cut and i'm only taking 160 home a week... but i am hopeing for the harness this week otherwards monday or tuesday.
Chris,
We're just about ready to send your complete harness out. There are a
number of broken plugs on the harness that we strongly recommend
having replaced. They are:
1 Cam Position Sensor Plug
6 Coil Plugs
1 VSV Plug
We have all new connectors here in stock, they are $15 each, so your
total will be $120 for replacing all of the ones I listed. Let us
know!![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
-Doc
6 Coil Plugs
1 VSV Plug
know!
-Doc
#96
Recession
I know what you mean. My budget is shoot too. $300.00 left to spend. If I go over budget My wife will kill me.
We are in a Recession. & School is very very Important. So good luck.
#97
I need to get it sand blasted and repainted :/
![](http://i79.photobucket.com/albums/j123/YellowTalon/DSCI0229.jpg?t=1224801606)
#98
If you haven't paid for the new connectors, they list for half that and go for about $5 each through Elmhurst Toyota which is a supraforms sponsor. Even if you went to your local dealer, they'd be cheaper. I have a bunch of spare vsv's and connectors which i can send you for a couple $$ plus shipping. Shoot me a PM if your interested. I know money's tight so hope this helps.
90980-10947 CPS Housing,sensor List $7.23 Elmhurst Price: $5.52
90980-11246 Coil Plug Black Connector List $6.18 Elmhurst Price: $4.71
#101
