Help! My SC Began to Overheat...
I have a 92 SC400, it just started to overheat today, I've let it sit idleing before and nothing wrong has happened, but today after about 15 minutes it started to overheat. I stopped put water in it and turned it back on, it was good for about 2 minutes then it overheated again... I need your help, this is the last thing I need.... could it be a leak or something?
Thank You...
Thank You...
UPDATE:
I put in some coolant (not water) and turned on the Heater I guess to flush system...The car doesn't over heat anymore...but I still here a hissing noise when I turn off the car...what could this be? I heard this yesterday and today it over heated...I don't know...
Registered User
Check for leaks first off, that should be obvious though. I would look around the plastic end tanks for cracks. My Soarer's end tank cracked near the radiator cap just from the plastic being so old. Also check to see if your fan is turning on. Does it flip on when the car starts getting hot? Maybe some trip sensor has gone bad. Only time my Soarer over headed was when a shop accidentally yanked out one of my wires to my electric fans killin em.
Yea thanks bro...I believe it's a leak...I have to check it out later when there still isn't anti freeze over spill dripping from the bottom...lol...
I'll keep you updated thanks!
SC400 has a hydraulic fan unless youve swapped to an electric fan. id do a pressure test of the system and check all hoses for leaks. sometimes its a tiny hose or it could be one of the 2 main hoses for the radiator.
first things first check the upper and lower hoses are they both hot if not most likely thermostat is stuck or possible water pump hissing can be from many things so after checking the hoses check for leaks by pressurizing the system
Also check the radiator cap. Its a 13lb pressure system and with the date of your SC it could be old an not able to hold the pressure which would allow the system to overheat and the hissing could be pressure escaping the cooling system via the cap.
jgm
08-17-07 08:39 PM
