Cant remove the crank bolt
Old 10-01-08, 12:49 PM
SC400TT
SC400TT's Avatar
Looks like that flywheel got damaged...Just use a compressor and an air gun...no probs when you use the correct tools...
Thanks,
Ryan Allen
Old 11-09-08, 03:26 PM
drft_n_VIP
drft_n_VIP's Avatar
im stuck here too...
- I dont have anything hooked up as far as battery or anything, so i cant try the crank trick.
- I tried a big@S$ bar like i did my sc400, and nothing
- dont have my air compressor yet
Whats the name of that tool? and seriously, where can I get one???
thanx
Old 11-09-08, 04:17 PM
LEX_MAN
LEX_MAN's Avatar
Its called chain wrench.You wrap it around the crank to hold it from turning.Then unbolt the nut with a big gorilla wrench.Its tuff but if you get some pipes to make the wrench longer its a breeze.
Old 11-09-08, 05:01 PM
drft_n_VIP
drft_n_VIP's Avatar
sweet thanx man!
Old 11-10-08, 07:40 PM
lemmiewink
lemmiewink's Avatar
Yes chain wrenches are a god send. Make sure to use an old belt or something in between the crank pulley and the wrench so you don't smash in the little notches on the pulley.
Old 11-10-08, 10:36 PM
JspecSC3
JspecSC3's Avatar
Thanks,
Ryan Allen
I agree. Most impact wrenches or pneumatic guns will not work. You have to find the crazy ones that are rated at about 500 psi. A couple taps with one of those and that bolt will come right off. Ive done it the starter way, didnt like it. The breaker bar is a pain. But the high PSI rated guns will get into that tight spot and loosen that bolt right up.
Old 11-11-08, 01:18 AM
dinhnerz
dinhnerz's Avatar
I have a very good gun for this. 1000ft lb of torque. Sometime it works with just gunning it. Otherwise theres other tricks. Spray PB blaster into the bolt and try it again. Try it with loosing and then tightening, repeat until out. Make sure use a black long socket for gunning crank bolts. Its all about the weight of the socket. Worst comes to worst heat that sucker up and gun it.
Old 11-11-08, 09:44 AM
SpinAll4
Former Sponsor - Cancelled
SpinAll4's Avatar
I use this guy:
AIRCAT Model No . 1603
3/4" impact with 1330 ft lbs of torque. Never met a bolt it couldn't break loose (or break off).
Great for the axle nuts as well.
Old 11-11-08, 11:46 AM
1985zcar
1985zcar's Avatar
damn, that thing is a beast. bet it cost a pretty penny. On my 1J we used the crank trick and it worked like a charm
Old 11-11-08, 05:47 PM
SpinAll4
SpinAll4's Avatar
EBAY for the win. It wasn't that bad, they come highly recommended by my snap on guy. Really quite too (like 84-85 db). The bad part is paying for a compressor that will run it right.
Old 11-11-08, 05:51 PM
shonuff53
shonuff53's Avatar
wow ppl I agree this is a tough task, but if you love your car Like I know you do since these are the best cars ever. then buy the crank pulley holding tool several companies have one I think Toyota's is about $51..
Old 11-11-08, 05:52 PM
JspecSC3
JspecSC3's Avatar
Originally Posted by SpinAll4
I use this guy:
Check that beauty out.
Old 11-11-08, 07:28 PM
ralsty
ralsty's Avatar
Great wrench that Aircat...what are the spec on the compressor pushing it?
Old 11-11-08, 07:54 PM
SpinAll4
SpinAll4's Avatar
I have an older sanborn that's a 60 gallon setup. You need the 3/8" fittings, and the larger hose to supply it as well.
Old 11-12-08, 07:45 AM
DKNY0331
DKNY0331's Avatar
200+psi of an air compressore with a 600ft lbs impact gun took it right off with ease.. but i tried a 450ftlb gun wont budge i think 215ish pis is when the bolt on mine ran right off.. you need to take the radiator out if you use a gun..a/c condeser can stay jus dont hit it
lastguy
01-03-16 09:53 PM
jwynn
08-11-15 09:14 PM
jwynn
SC- 1st Gen (1992-2000)
07-24-15 06:30 AM
WDoherty
01-08-11 04:06 PM
attzor
09-10-10 02:02 PM
Quick Reply: Cant remove the crank bolt
