SC300 will not crank???
Okay, here's the deal. My 5speed harness was involved in an engine fire so I had to replace it. I received one from R&J, but it was one with traction control and my sc does not have that option. I put the engine harness on (I left the extra TPS and ISC for the traction control unplugged) and everthing on the inside works, but the car will not even attempt to crank over (like a dead starter). I tried to test the fuel pump through the diagnostic port but found out that I had no power at all.
My question is...is there a difference between the two harness (they are both 5speed harnesses) and has anyone come across this before??? Thanks.
Josh
Josh
