did a compression test on my SC3...
Old 10-06-08, 05:22 PM
SC300_704
SC300_704's Avatar
Default did a compression test on my SC3...
this test was on a warm engine, btw some #'s might be a little off but not by much, should've wrote it down..is this still ok to turbocharge? i was just thinking about installing a thicker HG and ARP head studs...or should i rebuilt my spare shortblock w/ some used GTE pistons i bought awhile back...
cylinder 1: 160 psi
cylinder 2: 170 psi
cylinder 3: 150 psi
cylinder 4: 160 psi
cylinder 5: 165 psi
cylinder 6: 160 psi
Old 10-06-08, 05:37 PM
StiCk3
StiCk3's Avatar
numbers look pretty consistent overall. Green light for the turbo in my book.
I would just install the HG and the head studs unless you have some serious power numbers in mind.
Old 10-06-08, 05:48 PM
SC300_704
SC300_704's Avatar
if i would to have a low psi on the compression test then would it be b/c of the pistons/HG/or rings going bad??
Old 10-06-08, 06:10 PM
93sc3005sp
93sc3005sp's Avatar
most likely the valve seals which is recommended to replace during a hg change, when i did a cold compression test on my sc3 with 170k i cranked until it reached maximum psi on every cylinder which was around 180
Old 10-06-08, 06:52 PM
SC300_704
SC300_704's Avatar
i only crank it about 6 times max on each cylinder..maybe should've done more..and when it cranks it sounds kinda weak, i guess b/c i don't have the TB on or unplug any injector clips...
Old 10-06-08, 07:33 PM
clownin
clownin's Avatar
how many miles are on that motor if you dont mind me asking?
Old 10-09-08, 02:45 PM
SC300_704
SC300_704's Avatar
lol...good question, it has about 306K..that's why i did a compression test to see if it's still strong enough to hold up on BOOST! i'll be the first to boost a overmiliege SC300 lol....btw do anyone knows if that thing called RESTORE at the autoparts helps restore compression?
Old 10-09-08, 05:08 PM
IonFeright
IonFeright's Avatar
306k? wow!! I thought I was balsy boosting with 227k. I ran compression a few months back and it came back 190 on 1,3,4,5,6 and 175 on cyl 2 so Ill be replacing most of the seals. Good luck!
Nissanfan
IS - 1st Gen (2001-2005)
05-15-21 03:54 AM
sub786sub
15
03-31-16 08:18 PM
riot8088
05-09-05 05:26 PM
indypwr
03-02-04 11:02 PM
indypwr
GS - 1st Gen (1993-1997)
02-24-04 01:07 AM
Quick Reply: did a compression test on my SC3...
