(NEED HELP) Rebuild
i currently own a stock 93 5spd sc300 2jz-ge
approx. 160k on the motor and truthfully dont know that much else about the whole thing
im going to try to do most things myself and getthe learning experience but i dont even know where to start
someone help me out pllleasseee
should i go na or go gte?
Well since its totally stock, you can do a lot of the supporting mods before you jump into FI to better learn your car.
Suspension (All components, not just shocks and springs)
Exhaust
Engine Stuff (radiator, hoses, belts, pulleys)
Lighting
Supporting interior parts.
The NA-T or GTE question is so heavily covered here on this forum, don't expect a lot of responses. Everyone has an opinion and its been covered far too much. Search
Exhaust
Lighting
im going to try to do most things myself and get the learning experience but i dont even know where to start someone help me out pllleasseee
Another thing if your new to working on cars which i am guessing yes. Do the simple maintenance items first. Then once you get enough knowledge about the simple things then look into boosting it. Cause you should have some kind of area $$ wise on what your going to spend. Just make sure the maintenance items are done first simple as that.
Exhaust
Lighting
The NA-T or GTE question is so heavily covered here on this forum, don't expect a lot of responses. Everyone has an opinion and its been covered far too much. Search![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Exhaust
Lighting
If you want a reliable daily driver with some boost the 2JZ-GTE with stock twins is a good setup (coming from a good, reputable engine supplier of course). You could also look into the 1JZ-GTE swap as well, not as much kick as the 2JZ but it has plenty of potential and also is generally cheaper than the 2JZ-GTE swap. Use that good 'ol search function in this forum there are plenty of related threads on how to complete both the swaps.
platano47
SC- 1st Gen (1992-2000)
23
02-21-10 06:32 PM
