clicking sound on p/s
so i start my car, cold and the p/s starts making a rapid click sound. i thought it was starving for p/s fluid but checked and seems fine. filled right in between the top of cold and the botm of hot. i need help as i want to resolve this issue!
thanks in advanced
thanks in advanced
Thought do you have the air on everytime you turn your car on? Cause the a/c clutch makes a clicking noise everytime it engages. Have it off and see if the sound goes away. It might be that.
nope everytime i start my car now for the past few weeks.
my p/s always leaks though... sometimes it overflows im guessing cause some are left on top of the can under the cap. [on the lip i would say]
How do you know its coming from the power steering? Is the clicking at idle or when you move your steering wheel? Does it go away when the car is warmed up?
Also, might want to check all your fluid levels. If you're low on oil the valves can make a clicking sound as well.
