1jz/2jz power steering question
I'm in the middle of my swap, and I realize that the 2j and 1j resivoirs mount up at different places...here's the probmem: my 1j didn't come with the resivoir, the lines are cut.
Has anyone had any luck using the 2j resivoir with the 1j and just relocating it or something? I think I might try this, just seeing if anyone else has done so.
You need to use the 1jz one with it because the 2jz one gets in the way of the throttle body. Mine came with one, so it was no problem, but if yours came with the pump, just cut lines and no res., you could probably find a res. in the classefeids. Or if you're really desperate, go to Toyota and order one from an MKIV supra. I think they're identical.
