Excessive Emission?
Ok now I know there a term for what I'm about to describe, but after a 17 hour shift I can not think of it so I will describe the best I can.
Oh boy.............I know I'm going to sound like a Retarded Monkey for this lol.
Here is goes.................In the morning when i start my car it seems like there is an excessive amount of exhaust fumes coming out of the car. When I'm driving it is not noticible but the minute I stop at a light it almost looks like my has a small fire lol. It mostly happens on cool mornings, but sometimes it happens when it is 70 degrees out. My car is the only that is doing this, the other cars around me are not.
Any ideas of what could be causing this?
I have a feeling that your car is running rich or that you have a lot of moisture in the exhaust system which is evaporating. Do you have a check engine light on? If you have a misfire the car will run rich. Usually the car runs rich if cool in the morning also. If you can tell or not do you seen do go threw gas real quick? Check your maintenance items like plugs wires and intake cleaning. Make sure they have been replaced within a couple years. Make sure your intake is clean also which helps. Other then that there shouldn't be a real big deal on less you have a check engine light. Keep the updates later....
the closer you live to an ocean, the more likely this will happen due to humidity being absorbed into the catalyst. Should go away after about 10 miles of driving I would think, or like was said above, you're running really rich and the catalyst is working overtime to remove HCs.
In July I changed my plugs, Wires, Distributor, VCG's. I do have a check engine light on it is for my 02 Sensor in Bank 1, could this be causing it? Me and Gas really dont like each other much lol my gas mileage is pretty crappy.
DK Audio
94
10-31-15 11:59 AM
jdmtruong
Performance & Maintenance
14
10-28-05 02:48 PM
