1jz-gte, do I need brackets if I use supra tt motor mounts?
Old 10-12-08, 02:22 PM
romeo291
romeo291's Avatar
Default 1jz-gte, do I need brackets if I use supra tt motor mounts?
Okay,
I am trying to confirm the answer to this question because I've gotten mix answers from reading various threads. If I am using 1997 Supra TT motor mounts, and I am swapping in a 1jz-gte motor, do I need to get the brackets for it as well? I was told by someone who did the swap that he needed the brackets too, but several people have posted on this forum from before that they should be the same on both the 1jz and 2jz, so it's not needed.
If I do need the brackets, could somebody hook me up with the part number for those, I couldn't find the exact ones that was needed.
Old 10-12-08, 02:33 PM
OneJay
OneJay's Avatar
Compare the length of the mounts to the ones in your 2jz and compare the length of the brackets between the two. If they are the same then you're good to go. If the brackets are different lengths, you can always use the brackets from the 2jz if they are the right size to complement the mounts.
Old 10-12-08, 04:35 PM
romeo291
romeo291's Avatar
Yeah, I know that's the easiest way to find out but I haven't started the swap yet. I am just trying to get all the parts so I can just do everything at once and not have to keep running out and buying parts and stuff.
Old 10-12-08, 05:52 PM
mteele
mteele's Avatar
Could just order some brand new SC motor mounts, from what I remember thats what you need. Unless you really want a TRD motor mount or something like that, but IMHO thats overkill.
Old 10-13-08, 09:06 AM
romeo291
romeo291's Avatar
Hey Matt, the SC motor mounts are more expensive, I was told that the 97+ TT supra motor mounts fits the same and are better as far as the construction and material goes. I am thinking I don't need the brackets, but we'll see.
Old 10-13-08, 11:15 AM
OneJay
OneJay's Avatar
Well, just for reference, I got the 98 supra motor mounts and they fit perfectly. I'm not sure how the 97's compare in size.
Old 10-13-08, 11:45 AM
romeo291
romeo291's Avatar
Sweet! I think they should be the same, I am leaning towards not needed the brackets because it seems that everybody got the motor mounts only and they were fine. Thanx for the reply man.
xspsi6
SC400 / 300 Classifieds
11-28-12 04:53 AM
sidwin
11-15-12 07:13 PM
okula247
25
05-15-11 05:35 PM
nismo2trd
04-17-07 01:28 PM
jbiel
12-27-05 04:26 PM
Quick Reply: 1jz-gte, do I need brackets if I use supra tt motor mounts?
