Car won't start...
Old 10-13-08, 09:16 PM
rpx13
rpx13's Avatar
Default Car won't start...
I've been playing around with my suspension tryin to figure out a good stance and the other day jes messin around I set my coilovers pretty low and while I was driving around my neigborhood I hit a little dip in the road and my car bottomed out. I drove home no problem jacked up my car to re-set the coilovers and when all said and done and ready to park in the garage my car wouldnt start. I'm assuming when I bottomed out I mustve done something to the starter or the selenoid cause the battery still has plenty of juice it. When I turn the key all I hear is the fuel pump. Any advice or suggestions???
Old 10-14-08, 10:32 AM
rpx13
rpx13's Avatar
no one?...where are all my CL gear heads???
Old 10-14-08, 11:26 AM
ecstaticSC
ecstaticSC's Avatar
Check the wire harness in the driver side fender. The more you lower your car the easier it is for the tire to rip through the harness.
Old 10-14-08, 12:01 PM
unreal-
unreal-'s Avatar
Definately check the driver side harness. Low suspension + dip in road + Improperly set up coils/shocks + Horrible placement of wiring harness = electrical problems and/or car not starting.
Old 10-14-08, 12:08 PM
rpx13
rpx13's Avatar
hmmm...seems to be ok...jes checked it ...
Old 10-14-08, 12:23 PM
RolxuSC400
RolxuSC400's Avatar
Dude just checked your profile it states you have a GS 300 not an SC. Different things could be affecting that might not be known on this forum. If its a GS I'd suggest moving it to that forum for help.
Old 10-14-08, 12:44 PM
rpx13
rpx13's Avatar
I had a GS300 back in 01...I NOW have a SC300....do people really update their profiles????...jk
Old 10-14-08, 08:23 PM
SHOLEXMAN
SHOLEXMAN's Avatar
That bump most likley didn't do anything to your starter. Does it crank ,but not start? The fuel pump works do you have any spark? Do you have a check engine light turn on when you turn the key on? See if you can get any voltage reading from the fuel injectors or if you have a test light use that. See if you have spark and then tell me the results from your findings. Later>>>
Old 10-15-08, 01:58 PM
rpx13
rpx13's Avatar
...it doesnt crank or start...there is spark....yes, the check engine light is on...i think maybe the wiring harness got knocked out because after i removed the plastic fender lining inside i noticed the lil box where the wires are in was cracked...the wires looked like they were spliced open...i think that may be the problem...
Old 10-15-08, 02:01 PM
rpx13
rpx13's Avatar
thanks for your suggestion....Also to SC300STED...when i first looked inside my fender i didnt notice anything out of the ordinary, but i decided to take out my fender lining anyway and i noticed a big crack on the box where the wiring harness is housed...noticed that the red wire was spliced...im still looking into it....
Old 10-15-08, 04:41 PM
SHOLEXMAN
SHOLEXMAN's Avatar
Hmm that starter could be the issue and no power going to it.
Old 10-16-08, 01:21 AM
dinhnerz
dinhnerz's Avatar
How does it have spark if it doesn't crank? Does your car crank? As in does it turn over? What is your CEL code? There is a big possibility that the harness on your driver side is messed up due to being so low and rubbing.
Old 10-16-08, 10:19 AM
rpx13
rpx13's Avatar
we figured out that it is the wire harness on the drivers side....car is gettin rewired tmrw...ill let u guys know if it pans out...
Old 10-16-08, 09:55 PM
SHOLEXMAN
SHOLEXMAN's Avatar
Least you figured it out. I kinda had a feeling but didn't want to mention it. I remember this next time it comes up.
groundzer0
08-17-17 12:52 PM
sj408
SC- 1st Gen (1992-2000)
06-20-12 11:24 PM
jubay
19
04-07-11 07:30 PM
Bubbas SC
03-01-10 11:05 AM
HeisLegend
04-20-09 01:55 PM
Quick Reply: Car won't start...
