95 sc300 1jzgte mapecu install and map. need help please.
Old 10-14-08, 01:18 PM
sleeperSC
sleeperSC's Avatar
Default 95 sc300 1jzgte mapecu install and map. need help please.
i have a 95 sc300 with a 1jz swap. auto trans.
i have a mapecu sitting in a box i need to install. im having a hard time finding install instructions. i searched here and supra forums with no luck.
I also need to know what map to load and what settings to change once its installed. I will take it somewhere to get tuned but i would need to drive it for a little while until i can do this.
stock injectors for now, want 440s or 550s but dont have em yet.
60mm single, fmic, 3"dp, 3.5" greddy catback.
any links or info you can offer will be a big help. thanks
Old 10-14-08, 02:56 PM
TJohnson
TJohnson's Avatar
I've emailed the MAP ECU makers and got these two documents from them. One is the ECU pinout diagram for the Soarer ECU and then the PDF file is the hookup instructions for the 1jz ECU for the Soarer.
Attached Thumbnails 95 sc300 1jzgte mapecu install and map. need help please.-soarer1jzecu.jpg
Old 10-14-08, 03:04 PM
TJohnson
TJohnson's Avatar
Website is running slow for me here at the hotel, but here is the PDF that shows how to wire up the MAP ECU
Old 10-14-08, 03:57 PM
sleeperSC
sleeperSC's Avatar
amazing. thanks a ton.
ok so now i need to know what settings if any i need to change and also what map if any i need to upload to it so i can drive the thing.
can i just get it in there with no changes +/- on the map and run it like that? kinda how you would do with a new safc. 0+/- across the board?
im used to haltech standalone on a 13b turbo rx7.... not even close to apples to apples.
thanks.
Drew1jz92
SC- 1st Gen (1992-2000)
23
08-05-11 01:07 PM
96sc300
Florida Lexus Club
12
10-04-10 08:54 PM
dinhnerz
09-19-08 12:18 PM
Quick Reply: 95 sc300 1jzgte mapecu install and map. need help please.
