question about r154 swap
can you use a redrilled 2JZ N/A flywheel instead of buying a new 1JZ?
I was researching all these options and since I have access to a Soarer 1JZ I was looking to just pick up a 2JZ-GTE engine and throw the R154 to it. If I read correctly an N/A 2JZ flywheel will work if it's drilled correctly.
I was planning on just doing a 1JZ but I think I can still do a cost-effect 2JZ-GTE setup like this especially since I already have a factory 5-speed SC300.
Buy the 1Jz Flywheel and it's associated bolts. This is somewhere you don't want to cheap out. safety
Thank you for Agreeing with me, I seen a few Flywheels Explode from being weak from redrilling or too much resurfacing... Driftmotion FTW
sniper
SC400 / 300 Classifieds
12
09-05-14 01:37 PM
jayzsun
02-16-09 07:55 PM
