SC400 Cat Removal Help - Rusted Bolts
I've been able to get the 2 downstream bolts out, but have been struggling with the 3 upstream nuts. My 1/2" impact wrench sockets are bumping up against the cat so I can't get them over the nuts, so I tried a 1/2" to 3/8" conversion with my 10" extension and a deep 14mm socket. Any suggestions for getting at these bolts without using a 10" extension? Anything I'm missing?
Thanks in advanced, I'm going to go spray them again.
Either heat them up with a torch or cut them off with a cutting wheel only takes about 10 minutes max if that for 2 bolts. If there welded onto the pipe then just heat them up and spray them with some PB Blaster.
Bullochdaw
07-18-18 04:54 PM
2jzkilla
13
12-07-15 07:12 AM
dashan
06-08-13 07:19 PM
