Clickin Noise!!!!
Old 10-22-08, 08:38 AM
94_soarer
94_soarer's Avatar
Default Clickin Noise!!!!
im gettin the clickin noise when i go to start my sc....idk if its my battery thats died or if i jus need a all new starter.... but when i connect the battery and i turn the ignition on my gauges and led lights are way dimmer than usual...and same wit my headlights n taillights...wut do you guys think the issue is????
PLEASE HELP!!!!!!
Old 10-22-08, 08:47 AM
Biggu
Biggu's Avatar
sounds to me like its a dead battery, jump the battery or put it on the charger and let it charge.
Old 10-22-08, 09:04 AM
94_soarer
94_soarer's Avatar
man i aint ****in wit that battery anymore....lol ima jus get a new one...lol
but yea my windows are goin up n down extra slow and my antenna is too so u think thats wut it is????
Old 10-22-08, 09:37 AM
1985zcar
1985zcar's Avatar
Have you replaced the battery? That's obviously the first thing you need to do. If everything's working slow and you can't start the car, then it's your battery.
Old 10-22-08, 09:52 AM
StiCk3
StiCk3's Avatar
if all your accessorires are coming on but the engine has trouble turning over it's most likely a battery problem. Check the battery terminals for corrosion and clean it of. If that doesn't do anything replace the battery all together. An easy 2 minute job.
Old 10-23-08, 08:24 AM
LexusFTW
LexusFTW's Avatar
Rebuild your starter solenoid.
Old 10-23-08, 02:32 PM
SC30096
SC30096's Avatar
battery first if it doesnt help then its your starter contacts. if there is alot of corrosion on the contacts then you might not even need a new battery just clean them off real good with a baking powder solution.
Old 10-23-08, 02:53 PM
94_soarer
94_soarer's Avatar
Cool
thanks u guys but i got it fix....lol i feel like such a loser!!!!!! it was my battery...lol
worker
01-29-24 08:56 AM
stlgrym3
09-22-22 02:54 PM
DaNiELx626
06-29-10 10:43 PM
HarrierRX300
RX - 1st Gen (1999-2003)
06-14-08 12:25 AM
calichris
07-26-07 09:10 AM
Quick Reply: Clickin Noise!!!!
