93 SC300 Car Turned Off On Freeway
Old 10-24-08, 05:26 AM
xsahowx
xsahowx's Avatar
Default 93 SC300 Car Turned Off On Freeway
I just got my car a week ago. Did minor tune ups. Oil Change. Mobil 1 Full. Spark Plugs. Spark Plug Wires. Everything done by a mechanic. Its been running excellent until tonight when I was on the freeway going about 80 and the car shuts off on me and I was stuck on the freeway. Starts up and cranks and just doesnt start. Tow Truck guy said it might be the fuel pump. Any suggestions. Thanks guys.
Old 10-24-08, 06:44 AM
turbodremz
turbodremz's Avatar
there are a few different things that could have cause that. Check to see if you can hear your pump prime when you turn the ignition. if not start with the fuel pump relay, and make sure that its still good. then go for the pump its self.
Old 10-24-08, 09:05 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Welcome to the search button:
https://www.clublexus.com/forums/sho...=car+shuts+off
and the engine forum
Old 10-24-08, 12:04 PM
xsahowx
xsahowx's Avatar
help please
Old 10-24-08, 12:05 PM
xsahowx
xsahowx's Avatar
where is the fuel pump relay at?
Old 10-24-08, 01:49 PM
lemmiewink
lemmiewink's Avatar
The efi relay is in the junction block next to the battery.
If you remove it, your fuel pump won't prime/turn on
Old 10-24-08, 02:16 PM
xsahowx
xsahowx's Avatar
how do you know if its good or not?
Old 10-24-08, 02:35 PM
lemmiewink
lemmiewink's Avatar
You need a multimeter to check the relay itself.There are 4 terminals in the relay I believe you can test for continuity. 2 should be normally closed while the remaining 2 should be normally open.
You should then provide current to the 2 that is normally closed. If you do this you should hear a clicking sound from the relay. Check for continuity on the 2 terminals that are normally open. THey shoudl now have continuity as long as voltage is being supplied to the normally closed terminals.
if you don't have continuity to the normally open terminals with voltage applied, you have a bad relay.
Before you do any of this, try turning the ignition switch to the "on" position and listen for your pump. If you hear it then its not your relay.
If this don't work I would try to bypass the Fuel pump ecu temporarily by jumping 2 terminals in the engine bay diagnostic plug . Forgot which 2 though
Old 10-27-08, 03:00 PM
xsahowx
xsahowx's Avatar
is the pump loud enough to hear it.. Cause i don't think I can hear the fuel pump go on when i turn the ignition.
Old 10-27-08, 03:02 PM
xsahowx
xsahowx's Avatar
If I do the fuel ecu bypass would that help?
Old 10-27-08, 03:05 PM
TheMole
TheMole's Avatar
Do your electricals work?
Old 10-27-08, 04:13 PM
xsahowx
xsahowx's Avatar
All the electricals work.. It cranks and everything.. Just doesnt start up. A mechanic told me to spray starter fluid in the intake and it should start up. and if it does he said it might be the fuel pump or something like that. Is it common for the fuel pump to go bad?.. Car has only 118,000k miles.
Old 10-27-08, 06:27 PM
submarine
submarine's Avatar
Default Blown Fuse: A possiblilty ...
I put 40K of 130K original miles on my 96 SC400 and it died suddenly during a heavy rain storm (we get them often in FL and no problems before ). Turned out to be a blown fuse per Toyo dealer. No charge. I still question it and my dentist didn't believe it until I showed him the invoice. Today I have 8K more miles with no problems.
Old 10-27-08, 09:20 PM
xsahowx
xsahowx's Avatar
do you know what fuse it is?.. IS that the only fuse box thats on top by the battery.. or is there another fuse box somewhere in the interior of the car?
Cjet
ES - 5th Gen (2007-2012)
03-05-20 06:28 AM
92lexi
10-18-14 04:55 PM
anu7898
08-13-13 01:43 PM
95SC3T
02-22-13 11:10 PM
klepto2
12-04-09 03:36 PM
Quick Reply: 93 SC300 Car Turned Off On Freeway
