Sumebody Please Help!!!!
WELL I HAVE A 94 SC300 AND I TRIED TO START IT AND ALL I HEAR IS THE STARTER....AND IN ORDER 4 ME TO GET THE CAR STARTED I HAVE TO REV IT WHEN IM CRANKIN IT....THEN WHEN I DO THAT THE CAR WONT STAY ON....IT WONT IDLE!!!! IM SOOOOO MAD....CL HELP ME PLEASE!!!
Check your plugs and wires. This happened to me, essentially one of the valve cover gaskets was leaking onto the 3 and 4 plug wires cause them to misfire and not allow the engine to run at low rpms. It would sputter and fluctuate then just die.
I had tried all of the things product said first, because they are the most common causes so if none of those work check the sparks.
Hope that helps.
Hope that helps.
JDM2jz23
Performance & Maintenance
01-28-17 08:31 AM
