550 Injectors __ stock fuel rail???
LoL i have had the same question but i guess you guys asked for me... well i did some reseach and i found some things that I just want verified.... I read that the GTE injectors are side fed while ours are top fed (not sure if i am right) so GTE injectors prob will not work also I heard that 87-91 RX-7 Turbo 2 550cc injectors are drop in plug n play. But i am not sure if they have to be High or Low impedance ???? well thats my input i hope someone can correct me if i am wrong And is there anyother brand that sells direct replacements for GE engines that are 550cc+????
No supra 550cc wont fit, but you can buy rc injectors those will fit!I had some RC 550cc on my n/a fuel rail look in the supra forums you will see them pop out every once in a while!Yup rx7 550 fit had those on for a little bit.
how did the RX-7 injectors work for you??? also where they low or high impedance
if those rx7 injectors are high, then it's simply removing the old and installing these. the only other thing u may want to research about them are the plugs to make sure you don't need different pigtails.
scmaluco
Performance & Maintenance
08-15-12 02:07 PM
jroring
SC400 / 300 Classifieds
19
11-13-08 01:38 AM
That-Guy
10-26-08 11:35 AM
