Please tell me this is not a blown Head Gasket
Not a bad idea, I might try that until agila gets back to me, thanks. Can I keep this as a permanent solution or do I have to use the valve?
What exactly does a heater control valve do? I'm pretty sure its not the hose because the leak is coming from passengers side of the unit in the middle behind a screw. I'm wondering if I actually need this or can I just permanently by pass it?
Is the heater control valve on the 92-93 SC300 the same as the 97?
If its coming from behind the screw its the heater control valve. You can check it by running car and having a partner switch from full A/C to full heat. You will see that valve swing and coolant will drip, dribble or possibly squirt out.
I just had this happen and I got mine from Aliga on Friday!
Check out my thread...This seems to be going around right now.
https://www.clublexus.com/forums/sho...d.php?t=385733
I just sent payment to the HCV, I can not wait to stop filling my coolant every week.
6SOARER
Performance & Maintenance
11-26-10 02:52 PM
LexieLS
07-17-06 08:58 AM
