Need help asap!!
Need help asap!!
95 sc400 i changed the power steering pump for a junk yard special and after i did it my abs light is staying on, my sunroof wont work now and the power steering is only half the power steering it was before plz lmk if you can give me any insight thank you.
You got some crazy electrical problems there... might be a worse pump than what you have. Did you check your electrical connections? You might have unplugged something in the process of changing the pump. Did you check your fuses?
nothing seems to be unplugged and it worked fine for about a month and then went crazy on me. no fuses blown. also the psf bubbles outof the cap so theres always liquid around the cap.
i tried bleeding just like they said but i cant keep fluid in the res. when bleeding even ehen im not turning the wheel the fluid just keeps going threw
