**PLEASE NEED SOME HELP w/1JZ SC400***
Old 11-06-08, 10:38 PM
Huyzee
Huyzee's Avatar
Default **PLEASE NEED SOME HELP w/1JZ SC400***
Yo i need help with my 1jz sc400. It was already swapped by SNAP Performance in TX. Anyways when i bought my car the speedometer never worked. i've changed to a good working cluster and changed speed sensor. still no worky There is a box under the column that says speed control. Does that have to do anything with the speedometer? What should check next? any help would be appreciated
Old 11-06-08, 10:47 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Old 11-07-08, 12:12 AM
dinhnerz
dinhnerz's Avatar
There's a tach fix on the forum, you just gotta search for it. This is for 1jz swaps.
Old 11-07-08, 07:26 PM
CCC-TT
CCC-TT's Avatar
also check youtube, there's a video for the tach.
Old 11-07-08, 07:28 PM
OneJay
OneJay's Avatar
He means the SPEEDometer, not the tach. Is it manual or auto?
Old 11-07-08, 11:56 PM
BigManne
BigManne's Avatar
hmm mine works fine. i bought my car from snap also. is it the random wire that needs to be grounded near the ecu?
Old 11-08-08, 04:02 PM
Huyzee
Huyzee's Avatar
yes the speedo and its an auto
Old 11-08-08, 04:03 PM
Huyzee
Huyzee's Avatar
can u be more specific on wheres the wire is located on the ecu? thnks
Old 11-08-08, 08:02 PM
CCC-TT
CCC-TT's Avatar
If the swap is auto but going into a 5 speed car you must cut off the speed sensor harness from the GE then you must cut the one on the GTE and solder the GE piece so that it will connect to the sensor on the transmission
Matt300ZXT
SC- 1st Gen (1992-2000)
02-20-11 03:24 PM
Slow_Sc3
10-04-09 03:52 PM
JTJerryls400
08-10-07 04:38 PM
Ay-nako
11-19-06 12:00 PM
Quick Reply: **PLEASE NEED SOME HELP w/1JZ SC400***
