Is this the ignition or tumbler switch???
I went to start my car and when i turn the key nothing happens other than unlocking the steering wheel. I have power but the ignition doesn't turn on. No fuel pump, radio, etc. I checked all the fuses and they are all good. Does this sound like the ignition switch? I thought it sounded like it but when I searched on here it seems everyone replaced the ignition switch because the key got stuck or it wouldn't turn not because of what seems to be an electrical problem with it. Let me know what you think. thanks!
This is on a 1995 SC300.
im having this exact same problem. my key goes in and turns, but normally when you start turning key you hear the ignition engage. but now it makes no noise and car wont start battery is good and all fuses are good need help
what is wrong?
what is wrong?
i have the same problem.
but i tracked it down to the tumbler. i took the back part of the ign. switch off and turn it by hand and everything lit up and relays were clicking.
for some reason the key cylinder isnt turning the switch.
yup. its cast steel and you cant weld it.
im goin to a junk yard tomorrow with 2 sc's.. i bought a slide hammer today so im going to rip the front part of the key cylinder out then grab the little cam-shaft type thing
