Need intake help fast!
guys its 12 at night and i have school tomorrow... and only i would manage to mess up the simplest damn thing!
i put on a new intake i bought has a k&n filter and all of a sudden my car starts suppudering when i rev it.... i dont know what i did wrong.. i went back made sure everything was correct and for some reason its suppdering...
also i took off the filter and when i rev past probably 3.5 rpm the MAF makes a weird farting kinda noise... i donno what to do...
PLEASE help.
thanks guys.
PLEASE help.
thanks guys.
k&N filter oil may have went on the MAF sensor.... might want to check it out, but hope thast not teh case. hope you can get it done before school. GL
haha yes it is. and so are the other 2 hoses. and thats it.
i really hope my maf didnt take a **** cuz thats what im thinking..
but if it went bad then the car would immidiatly be bad....
i was also maybe thinging it had something to do with my throdell cables? i did touch them but nothing bad.... i know nothing about them... maybe thoes? are lose or something?
with something like this, it is almost always something left unplugged, loose connection, etc... go back over everything you did and re-do it... it's normal if you installed a air filter that removed the air box for it to make some kinda weird noises...
when the car was first started after the air filter was installed did these symptoms come about? if it was immediately, I wouldn't think it would be the oil from the filter on the maf that quickly, however it could potentially happen... how wet is the air filter with oil? if it's not dripping, then that is probably all but ruled out...
go back and check all your wiring connections, look at other things that coulda been bumped as well - coil pack connections, etc...
did you pinch the plug to MAF on accident while removing the intake or removing the plug itself? inspect every connection. the two small vacum lines wouldnt make your idle jump past 500rpms of range. but if your MAF isnt working, it would.
try resetting the ecu as well. could just not be used to the non restricted air.
unplug the battery for about 5-10 minutes
thats why buddy
you installed you MAF backways lol
flip it so the plug is facing teh engine and not the fender wall
cheers![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
underneath the MAF sensor you will see an arrow, that arrow represents the flow of air, so make the arrow point the passanger/driver seats.
cheers
ok ima try that... im trying to upload all the pics off photobucket... the MAF is perfectly clean and pluged in....
the car starts fine and runs but after 15 sec or so it starts to like sutter and about to die.. and then if i try to rev it it almost doesnt let me... it like boggs out or something..
