JVTR aluminum radiator
so i got a radiator cause of a killer deal through a friend. i helped him out and he decided to do a bit of a favor for me as well. i got the JVTR aluminum radiator. Dual core radiator. about 2.5" thick and pretty nice. welds seem good as well. also got two 14" electric fans with it. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
so heres the radiator. a dual core JVTR aluminum radiator for the mkiv supra [mt, no tranny oil coolers] on its way with intalling the fans and wire ups:
![](http://i304.photobucket.com/albums/nn197/anteatsrice/IMG_7173.jpg)
make it look clean now![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
![](http://i304.photobucket.com/albums/nn197/anteatsrice/IMG_7179.jpg)
front side:
![](http://i304.photobucket.com/albums/nn197/anteatsrice/IMG_7177.jpg)
before:
![](http://i304.photobucket.com/albums/nn197/anteatsrice/IMG_7171.jpg)
after:
![](http://i304.photobucket.com/albums/nn197/anteatsrice/IMG_7180.jpg)
![](http://i304.photobucket.com/albums/nn197/anteatsrice/IMG_7181.jpg)
![](http://i304.photobucket.com/albums/nn197/anteatsrice/IMG_7184.jpg)
just wanted to share, not sure if its all that helpfull but just to get the idea on how it would work~![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
note: my sc is a 5spd. auto sc's cant use this.
front side:
before:
after:
just a bit of advice from experience.
In the photo showing the front of the radiator where you can see the bolt - washer - nut.
change the washer for a larger one, and glue a thick layer of gasket cork to the washer that contacts the alloy tubes of the radiator so that it wont rub through as quick.
take it out a get someone to weld on tabs to mount the fans on and off the radiator tubes aswell (so you can fit the thickest coin between the radiator tube and fan)
haha thanks travis! which a special thanks goes to you for all the info ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
almost a direct drop it. you can drop it in and itll fit/ run fine, but for a perfect you can do some modding that can take no more than an extra hour so.
thanks ill look into that
posted up^^^
ahh but my sc is 5spd. never said it was auto.
posted up^^^
no, no big drop in operationg temp.
seems just the same [right below the half way notch in temp gauge], but i have no more issues of my car getting too hot when sporting it
haha i saw that thread of yours bro, very clean sc400. i actully read your thread up and down just incase i had a little thing to look out for. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
and the the fans, dont have a brand... they just came with the radiator. all i know is that they are 14" 12v @ 80w each
haha thanks, were all lucky to have a sc atleast
and yeah im not going to be deleting the abs for awhile now. not untill i can fix up my other dd. so far i just deleted the CC and soon the AC.
