IS300 hedder on 1992 sc300
Old 12-10-08, 07:22 PM
want sc300
want sc300's Avatar
Default IS300 hedder on 1992 sc300
will is300 hedder fit on my 1992 sc300, i know the the only main difference in the motors is the vvti
please help
Old 12-10-08, 10:04 PM
OneJay
OneJay's Avatar
You will need to modify the flange as the bolts on the VVT-I are different. I believe it will come pretty close to our downpipe though. I've heard of people using them.
Old 12-10-08, 10:07 PM
JspecSC3
JspecSC3's Avatar
They will bolt to the head but not to the piping. You'll also need to run IS300 or universal O2 sensors since the ones on the 1992 are the 2 bolt types.
Old 12-10-08, 10:32 PM
5sp_jzz30
5sp_jzz30's Avatar
the is300 has a different header design then the sc300. the sc300 header is a 6-2-1 design and the header merger into a single pipe right as it starts to go under the car.
the is300 header will bolt up but it is a 6-2-1 but the it stays 2 separate pipes all the way under the car. the pipes merge into 1 when it is half way down the car.
if you want to see what im talking about do a Google or eBay search on the sc300 and is300 header. you will see the difference.
it can be done you just need to have a custom exhaust made to go merge the 2 header pipes into one and connect under the car to your existing exhaust.
Old 12-10-08, 10:36 PM
horent135
horent135's Avatar
Will 99 sc300 vvt-i header work on a non vvt-i sc300 like a 95? Cuz when i check out my friend 99 sc300, his header looks huge compare to mine
Old 12-10-08, 10:48 PM
5sp_jzz30
5sp_jzz30's Avatar
all non turbo 2jzge headers, vvti or not, bolt up to the head.
the vvti sc300 header os nicer. it is a stainless primary design instead of a crappy cast old style garbage. wow i just sounded like a 6 year old describing this stuff. need sleep. im out.
Old 12-11-08, 07:48 AM
rwdanthony
rwdanthony's Avatar
but does the sc300 vvti headers have any more performance ups than our regular 2jzge manifolds other than material?
Old 12-11-08, 06:26 PM
want sc300
want sc300's Avatar
thanks good input
ronricorum
SC- 1st Gen (1992-2000)
12
12-16-09 11:28 AM
510SC300
08-22-08 10:32 AM
SC300_704
09-13-07 05:27 AM
Quick Reply: IS300 hedder on 1992 sc300
