What oil do you use in winter?
I live in the pacific northwest and i'm noticing some really cold weather, it's been below freezing the past couple days and snowy. This is my first winter with my SC so i'm wondering if any of you guys use 0-30 motor oil?
I usually use 5-30 castrol high mileage (cause my motor has 200k)
Thanks,
Joe
Thanks,
Joe
im in toronto and we get pretty bad winters here. at least bad compared to most of the US. i have some castrol syntec 0w-50 lying around here that i got free from castrol. just wondering if i should use it or not for winter? since im gonna be doing an oil change in a few days.
Thicker the oil for hotter weather. Thiner the oil for colder weather flows a lot better. 0w-20 for colder northern states. 5w-20 or 5w-30 at the coldest for the lower southern states that don't freeze as much.
That doesn't mean it's ok or good for your motor. 305K or not. If you don't drive it hard all the time and keep up good maintenance sure you can run the same all year, I'm not saying it's going to blow your motor or anything or cause major damage if you don't. But it does make it easier on your motor if you change it.
I run 5w-30 year round. We have a lot of days in the winter where the temp does not get above zero (like today.. high of -8 or so) and I haven't had any problems.
