Mysterious coolant leak.
I'm in Killeen, about 45 mins from austin, and three from dallas or SA. I do a good bit of work on Toy/Lex, but our shop is mainly NSX'es. I do happen to have a MKVI supra radiator here, it's a koyo unit.
Also you'll need a trans cooler if you decide to do it. I have it on my SC400, and it works great!
Please don't do that! You risk blocking that and everything else in your cooling system. Thats putting a band aid on the problem. Same thing also using a egg. Don't do that cause you could as mentioned before clog your heater,thermostat,heater control valve,or other small area in the the motor. Replace it with a discount one cause the dealer ones are costly. You could go performance after market and get a Misimoto or something along those lines plus you get better cooling.
