2jzgte....swap/prep...........progress!
Old 12-22-08, 02:13 AM
wanganstyl
wanganstyl's Avatar
Default 2jzgte....swap/prep...........progress!
for people wanting help on wiring, start reading:
https://www.clublexus.com/forums/per...gured-out.html
finally had some time to rebuild the motor going in my sc300
taking it home in the 22R truck!
JDM jza80 longmotor ; 38k miles
tearing it apart:
hello oil squirters; you are the real deal.
stripped......down to naked block for new bearings:
removing valvetrain parts
VVti GTE intake cam on right, non-vvti GTE intake cam on left
head(s) on bench
back from the crankshop
crank in:
Old 12-22-08, 02:34 AM
wanganstyl
wanganstyl's Avatar
pistons and new rings and rod bearings in:
oil pan in:
head on block:
valvetrain in:
valvecovers on:
PDF toyota FSM for the win!
more accesssories coming soon!
waiting for oil pump o-ring from toyota, and the 6mt dampener =)
and a turbo setup. JDM intake manifold with usdm fuel rail going on tomorow. No EGR anywhere FTW!. no egr in the head, no egr delete to install, etc.
Old 12-22-08, 06:18 AM
ICONYQ
ICONYQ's Avatar
just FYI you might want to fix a couple of the pics...they do not show up.
Did you put it all to stock specs or did you change some stuff out like cams and injectors? Looks nice. What are you doing on the wiring harness?
Old 12-22-08, 09:26 AM
wanganstyl
wanganstyl's Avatar
rebuilt 100% to factory spec.
no need to change cams unless you really need top rev end power, 2jz makes power from MORE BOOST (although cams will gain for sure, as 2jz flows ridiculous)
im running a usdm MK4 550cc injector rail right now, i may go 650cc as I havnt decided turbo setup yet
either usdm twins rebuilt or a t04R if i can find it.....
Old 12-22-08, 05:15 PM
HeisLegend
HeisLegend's Avatar
awesome stuff.
Keep it alive.
Old 12-22-08, 07:43 PM
rwdanthony
rwdanthony's Avatar
good stuff! do it right.
and keep us posted.
Old 12-23-08, 07:28 PM
StiCk3
StiCk3's Avatar
looking nice keep it up!
what kind of ECU setup are you running now that you've changed to the USDM 550cc injectors? Are you using a piggyback or a standalone?
Old 12-24-08, 05:18 AM
wanganstyl
wanganstyl's Avatar
thanks for the comments guys.
theoretically, using an AEM with its map sensor and making a loom for ignition and cam/crank sensors to feed aem GTE style and retaining all other OEM sc300 wiring setup would be the simpliest
I'm also working on putting together a single setup, going to be running full jza80 SMIC setup to begin with with hard piping.
i have the JDM aristo wiring harness i may work in if i choose to run a jza80 AEM; otherwise if i can locate a sc300 AEM EMS, i will be doing:
aem ems plug and play for sc300; aem should be ok for high or low impedence injectors (or i can wire in a resistor pack no sweat). for cam and crank signals, ill use OEM GTE (as i can), was pondering converting the sc300 2jzge wiring to run with waste spark, but will probably be easier to find a 3kgt ignitor to power the gte coilpacks i have or run LS1 coilpacks with built in ignitor (1 ignitor per coilpack instead of 1 per 6 coilpacks ala 2jzgte oem setup.
with the turbo i am going to run and what the car is being setup for; stock ems or stock+piggyback will not cut it :P
550cc is for break in, idle maps etc. wont stay like that for very long
Old 12-24-08, 05:49 PM
wanganstyl
wanganstyl's Avatar
more progress:
timing belt game. won on first try.
yay waterpump o ring/gasket in from Toyota; waterpump in. OEM 82C thermostat, had a 63C prior.
front business is on.
supra 2jzgte 6mt tensioner dampner. apparently not the only thing Toyota puts it on, as it was only a day or 2 order.
ancillary's bolted on:
Old 01-03-09, 07:28 AM
wanganstyl
wanganstyl's Avatar
twinscroll ftw
holset HX50
Old 01-03-09, 09:43 AM
Biggu
Biggu's Avatar
damn it looks great! how much power you looking for outta your car?
Old 01-03-09, 11:03 AM
wanganstyl
wanganstyl's Avatar
id say 5-600 rwhp happy street on pump/water injection would be the goal, don't really have access to race fuel, unless i can locate a barrel of C16....... hahahah
Old 01-03-09, 11:28 AM
SC34M3
SC34M3's Avatar
are you from socal? just curious ..might need a worker for my car one day. good luck on the swap!
Old 01-04-09, 04:13 AM
wanganstyl
wanganstyl's Avatar
sf bay norcal; im a Grad student: winter break is a great time for engine rebuild!
Old 01-04-09, 06:39 AM
OneJay
OneJay's Avatar
Looks like a great job on the rebuild, and you should have a buttload of power with that single setup!
What part of norcal btw? And what school? I go to Santa Clara.
Quick Reply: 2jzgte....swap/prep...........progress!
