just swapped a 2jzgte motor and the climate control unit doesnt work!!! i searched
well heres the story.
my AC and climate control and everything was working fine before the swap. after the motor went in and everything wired up the car started just fine. everything was running and smooth.
but there was a plug under the glove box on the passenger side with 5 wires that was supposedly there to control the climate control. the harness was too short. so finally i got around to extending it. plugged it up and nothing.
my lcd lights up. but none of the lights on the buttons light up and the **** doesnt do anything. no beeps no control over anything.
another strange problem was that my cig lighter is no longer working, i know these 2 are tied but i checked all the fuses and there fine.
we used the ge harness to power the acc in the car and just added wires and pins for the components needed for the gte motor.
did i miss something or need to wire something else?
if you removed the bezel or trim that goes around your shifter and then up all the way around the climate control, theres two plugs in the upper left corner ensure they are connected securely. dont know if this will help but one more possibility can be ruled out. my black little box connection always comes of when working in that area.
