after car warms up , starter will not kick in
Old 01-03-09, 06:28 PM
pandulce
pandulce's Avatar
Angry after car warms up , starter will not kick in
I tried dis connecting the battery for a bit to reset but no dice,seems when it warms up it does not want to start, starter does not engage at all, but when its cold the starter kicks in on many tries. I checked one of the fuses but seems ok but the fuse in the engine compartment is hard to check because its a square little box fuse or relay? any suggestion?
Old 01-03-09, 07:42 PM
TLDriver
TLDriver's Avatar
go get your starter tested. You will have to take it off but.. go get it tested.
Old 01-03-09, 08:33 PM
JspecSC3
JspecSC3's Avatar
Reseting the ECU will not help the starter. I doubt checking the fuses will help. The starting solenoid might be going. I would go get it tested. You'll most likely have to have it replaced or rebuilt. Goodluck.
Mattkz
07-07-23 03:13 AM
Nonnname
13
12-04-16 07:16 AM
flyhigh123
12-01-06 09:08 AM
RA40
Maintenance
03-03-05 01:09 PM
Quick Reply: after car warms up , starter will not kick in
