Another 2jz-gte swap thread...
Right now my plan is to swap a 2jz-gte with auto tranny into my 94 auto sc300. Up until last night however, I was convinced on going with the 1jz and auto tranny. I did all the research on what I needed to buy, but at the last minute decided to "go big or go home".
I am not here to ask if it will work, or if stuff will bolt up because I already know it will. My question is what all do I need to buy in order for this swap to go as smoothly as possible? I spent last night searching but most of the information was for people swapping into a 5spd sc or sc400.
These are the things that come with the engine:
COMPELTE ENGINE
AT TRANSMISSION
COMPELTE ENGINE WIRING
ECU / COMPUTER
POWER STEERING PUMP
STARTER
AC COMPRESSOR
ALTERNATOR
EXHAUST MANIFOLD
INTAKE MANIFOLD
TURBO MANIFOLD
THROTTLE BODY
INJECTORS
FUEL RAIL
COILS
PULLY
I know I need to buy:
Turbo Timer?
Replace gaskets?
Downpipe
Greddy Speed Cut Controller
Electric Fans
Supra Intercooler
Cam Seals
Front Main Seal
Rear Main Seal
Water Pump
Serpentine Belt (with AC)
Timing belt
1JZ/2JZ Lightweight Underdrive Pulley Kit
2JZ Throttle cable
Transmission Mounts
2x Motor Mount For 1JZ/2JZ/7M
Toyota Oil Filter
6x NGK Spark Plugs and Wires
Supra Upper/lower radiator hoses
MSD Tach adapter (for the tach)
330ohm resistor (for the temp gauge)
Walbro fuel pump
A spool of 18g wire
Heatshrink/Solder
Fluids (oil, transmission fluid, coolant...)
Is there anything else should I think about replacing when I do this swap?
Thanks
COMPELTE ENGINE
AT TRANSMISSION
ECU / COMPUTER
POWER STEERING PUMP
STARTER
AC COMPRESSOR
ALTERNATOR
EXHAUST MANIFOLD
INTAKE MANIFOLD
TURBO MANIFOLD
THROTTLE BODY
INJECTORS
FUEL RAIL
COILS
PULLY
Turbo Timer?
Replace gaskets?
Downpipe
Electric Fans
Supra Intercooler
Cam Seals
Front Main Seal
Rear Main Seal
Water Pump
Timing belt
2JZ Throttle cable
Transmission Mounts
Toyota Oil Filter
Walbro fuel pump
A spool of 18g wire
Heatshrink/Solder
Thanks
If you are keeping it auto, Try to snag the a340e out of the TT. It's essentially the same tranny but does not require a kickdown cable, and our stock kickdown cable is not long enough due to the different throttle body location.
As you are going to hear the time to go single is now, If you plan on it, but you already disclosed that you are one of those "shop do-it for you people", so it really won't be your burden later anyways.
I personally don't understand why people with realistic power goals scoff at using the stock GE and blow tons of money on GTE swaps, but more power to you. In the end your car will probably be worth more with the GTE. Good luck, hope all goes well for you.
I don't plan on going single anytime soon.
Trust me, I've spent the last year debating NA-T vs swap. The major weakness of my car is the 200k stock auto tranny. The great part about the swap is I get a low miles auto TT tranny with the reliable HP of the 2jz-gte.
Loving the input guys, feel free to add anything to my list too.
Banned
IMO if your not going manuel, your not going big. I swear the 5spd manuel is soo much better then any auto. Going down hills and around corners, truely makes the manuel shine.
Plus your in FL, that means none of those pesky carb laws. I would personally just buy a 1jz/r154. Then combine then together for a 1.5jz. You'll essentially have a 2jz with a worse flowing head. Since your power goals arent that high, their no point of spending extra money a 2jz when you'll be better off using that money on a manual tranny.
Let me put it this way, i spent 2 months looking for a good manual sc just because i thought the manual tranny as that much more important to have. Their were times when i questioned what i was doing and if i just should have just settled for an auto. Well right now i am looking for a sc400 for my bro and i can say 100 percent i am sooooo happy i got the manual.
Unless your left leg is broken get a manual transmission.
To keep your car auto is your preference. Some people actually like the luxury aspects of the SC300, and are not simply trying to build a poor mans MK4 Supra. I can agree with Ryeno, If you want a manual car, take the extra time to find one. I'm about to start my auto>R154 conversion and the most challenging spot looks like the pedal swap.
Banned
Until somebody decides to flow test the 2JZGTE head, the 2JZGE head, and the 1JZGTE head (this might have recently happened and I wasn't aware) Please don't post mis-information. The unwarranted claims about which head flows better are some of the most annoying things posted on JZ related boards. To me it's right up there with the Folklore that the GE bottom-end blows up at 400hp.
But anyways even for DD i still rather have a manual. Lets see i am 18 now and have been driving autos for 2 yrs. Well now that i have my manual idk how i ever drove those autos. It kinda sucks driving in LA or OC traffic but even then its worth it for when i dont have traffic.
Also it's funny when i get inside an auto car. my left leg just auto presses the floor. And then i realize autos dont have clutchs or thair safery switch. Like-wise when i break, i feel the need to press the floor with my left leg.
Its just IMO that if your gonna pay for labor to begin with to swap out an engine/tranny. you might as well swap in the manual right now. Cuz is you actually care about getting more power and everything your going to end up caring that your car is an auto.
guys it's basically a stock 2JZ-GTE with low miles on both engine and tranny. Little is being modified about the engine so it is going to be reliable which is what he's looking for. With the auto it really isn't all that bad. For city driving i would prefer a relaxing auto than a manual. Still, a future upgrade should include a manual if you want to crank up the power.
