middle of working:Need help fast
Old 01-06-09, 07:51 PM
ScSlide
ScSlide's Avatar
Default middle of working:Need help fast
I am trying to take off the crank shaft pulley but it keeps spinning...
sorry for the crappy cell phone pics this time...
Thank you in advance.....
Nick
Old 01-06-09, 08:07 PM
madmax98
madmax98's Avatar
Please save your self some heartache and put your starter to use. put your socket on a torque bar<you can extend it with a cheater bar too> then stabilize your combo on the battery side. disconnect your efi fuse then blip your starter, just blip it, that's all it take to spin that f'ing bolt. did it many times..let me know if you have any other questions
Of course, in these times when every one blames everybody but himself i have to say <USE AT YOUR OWN RISK>
Old 01-06-09, 08:15 PM
ScSlide
ScSlide's Avatar
Correct me if im wrong but dont you want to have it at TDC before take it off?
Old 01-06-09, 08:17 PM
ScSlide
ScSlide's Avatar
also where is the efi fuse?
Old 01-06-09, 08:33 PM
OneJay
OneJay's Avatar
You can also just disconnect the ignitor instead of pulling the efi fuse.
Old 01-06-09, 08:40 PM
madmax98
madmax98's Avatar
Com'on bro,
EFI fuse, in the fuse box, and it says EFI on it.. Are you sure you're up to this bro? What are u trying to do? "help me help you" lol
Old 01-06-09, 08:41 PM
madmax98
madmax98's Avatar
No, you're just loosenning the bolt, the pulley is gonna move no mater what..
Old 01-06-09, 09:06 PM
ScSlide
ScSlide's Avatar
im trying to put in a new water pump and timing belt.... and im trying to get the bottom cover off but in order to do that you must take off the crankshaft pulley
Old 01-07-09, 01:43 AM
madmax98
madmax98's Avatar
Slide, what year is your car? Do you have the manual or procedure describtion? Any luck with that crank bolt yet? let us know..
Old 01-07-09, 08:36 AM
wanganstyl
wanganstyl's Avatar
have somebody sit in the car, put car in 5th gear and hit the brakes
then use giant breaker bar on the 22mm bolt
then you need a steering wheel or harmonic dampner pulley to remove it.
when you remove it, you will see the woodruf key pressed into a slot in the crankshaft. those should be replaced if they look worn, bad/worn woodruf key is stepping into miata short nose crank or rb26 issues. bad. replace if worn, they are $2 dealer
Old 01-07-09, 01:55 PM
ScSlide
ScSlide's Avatar
gave up on it last night i guess im going to go and try it today...
no i havent got it off yet.....
Old 01-07-09, 02:56 PM
SC300_704
SC300_704's Avatar
should've loosen the bolt first before you took everything else apart, it'll make everything easier..what i did was this, used a big torque wrench w/ the correct socket size and lean it on the ground, unplug the coil ignition and then go inside and crank the car, it should automatically loosen the bolt...this is for an SC300 of couse...
Old 01-07-09, 03:21 PM
lemaylexus
lemaylexus's Avatar
Check this out. Hope that helps.
Old 01-07-09, 03:48 PM
ScSlide
ScSlide's Avatar
i tried getting it off using the brakes and putting it into 5th gear but my wrench is only about a foot long not long enough to get enough leverage... its ****ty
Old 01-07-09, 04:24 PM
wanganstyl
wanganstyl's Avatar
only one solution: buy longer wrench, or steal neighbors fencepost to put over your wrench.
Quick Reply: middle of working:Need help fast
