JZX100 VVTI 1JZ to SC300... Who has done it?
#31
The VVTI motor is sweet i must say. The only reason I didn't go with it while I was in Japan is because there is not much supporting mods for it. And it's a pita to tune.
GL with the swap, everything looks great.
#32
I am doing the same swap right now, got it running the other day, lots of odds and ends to finish up. Started right up first try. One suggestion to everyone doing the swap do not lose any parts, they are pricey. Still waiting on a tps for the vvti to come in. Hopefully finish it up in the next two weeks.
Mine is a 99sc with a chaser vvti motor, stock auto trans, front mount.
#36
It all depends on how many connectors u need replacing shipping to and from. He may have changed pricing for the swap, i think i was done with shipping and some connectors replaced for 600 or so. I am sure its a ballpark think as it will depend on what needs to be done to each on a case by case basis.
#41
I just subscribed to this thread! I think this is where i need to be!
I am doing a 1jz gte w/R154 swap right now and want to try and get this build up and running asap.
Current car = 1997 sc300 automatic
Project engine= 1jz gte w/ 5pd r154 (probably a chaser motor and tranny)
My major issues/concerns are:
1.R154 tranny doesnt fit into sc300 correctly as it seems to be a little short. I have been told to get it extended (around $350). Are there any other options to getting this tranny to fit into the car
2.Since this is a JDM motor what will I need to do to make the ECU and harness fit and work correctly
3.Going from auto to 5spd mt = will i need to change my driveshaft completely or are there any quick mods i can do to avoid paying for this
4.Will I have an issue with the LSD going from auto to manual or will that be fine ( i know that i will be loosing out on some power but if thats the only issue I can deal with it until I can afford to change this) Building on a budget now adays.
I will be posting pics up of my build once I get my camera back since i lent it out.
#45
and video
http://www.youtube.com/watch?v=vBNbKyqbxZk
http://www.youtube.com/watch?v=v1iUVbb_Rt0
