what is the disadvantage of turbocharging a automatic?
#31
#32
your talking about 1/4 mile quicker....auto does have its advantages but its out of the hole where its better..once rolling stick is better......
as far as spool up theres no differance...
#33
Originally posted by SC300TURBO
auto or stick dosent matter on turbo spool...its the rpm that generates enough exahust gas energy to spin the turbo and create posotive pressure......thats what mater...and that depends on the displacement of the engine and the size of the turbo...
wayne....i havent seen ya around...looking forward to seeing the car.....ill be at towers on friday...with my truck...
and toyomoto is the best way to go...its $5500 not installed for the stage 1.....very high quality and great power....Jeff
#34
Originally posted by Lex Luthor
Been to the track with her yet wayne?
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#35
awww..cool wayne...i didnt know you had gone the boosted route.....congrats....get that tranny fixed already
im still working...actually waiting for lance to have some time to get my car back in the shop to get things sorted out...shouldnt be too much longer....Jeff
#37
Unless you are prepared to shift your manual box without using the clutch or lifting the gas pedal the turbo/turbo's will spool down during the gearchange, this don't happen with an auto box once you get rolling on boost, it's full boost all the way.
I know we have had a long discussion on top speeds, I recall the US cars are limited to 140mph (approx), my own JDM Soarer was limited to 112mph when it arrived in the UK, now removed it will top 150 with ease.
It's commonly thought the A340 autobox can handle 450bhp before needing any work (other than good clean Toyota Type4 fluid), shortly I should be able to tell you if this is the case and if it will top 165mph.
#38
Im a newbie that might buy a auto sc300, simply becuase there are no manuals, NONE whatsoever in my area. But wouldn't swapping a auto supra transmission solve this problem? Also would a auto to 6 speed converstion be affordable or possible?
I've heard that auto supra transmissions are gear limited to 190 mph. Main reason Im buying the sc300 is becuase of the 2jz-gte swap.
Would the supra transmission (auto) bolt right in?
#39
i have a auto sc300 turbo, and im only running 5psi of boost and i was wondering,
does anyone know if supra pistons will work in the sc300 block, because im going to be
building the engine to handle up 2 600 hp. and where do you guys think i can get my tranny rebuilt to handle
that much power, and how much would it cost to get the tranny rebuilt?
#40
Chicago Lexus Club Moderator
Originally posted by Slick Lex Coupe
Something else to consider with the auto is that you can't go any faster than 140mph. A stock 300 runs up there pretty quick so a 400+ hp one would be right up at redline in top gear in no time at all. 140mph is fast, but I would want faster with a high power car. I like the late night highway runs.
Chris
PS. lexcoupe (Kevin) went 155 mph with 5 speed.
#41
What kind of "late night highway runs" are you guys talking about....and where? 140 MPH on a public road is insane....you could wind up in jail.
#42
Im heading out to the test and tune track tonight with a pretty much bone stock Soarer.
I have a feeling i'm just going to hit mid-low 14's
Mods.
Gutted Cat (leaking a little)
AFC
.8 bar boost
Supra brakes
Big fat Supra TT Rims (17")
We'll see how it goes. It will be my first time doing drags.
Mods.
AFC
.8 bar boost
Supra brakes
#44
Originally posted by Dimcorner
Ok..
Here are the best times
1/4 - 14.644
MPH - 98.87
I dunno if i should be happy about these times
Ok..
1/4 - 14.644
MPH - 98.87
What diff do you have?
What stall speed for the converter?
auto, automatic, automatice, car, charging, end, good, launch, rear, sc300, stock, turbo, turbocharge, turbocharger, turbocharging
