1jz swap problem...
Old 01-12-09, 11:09 AM
sunrisetrd
sunrisetrd's Avatar
Default 1jz swap problem...
I received my 1jz engine today. Everything looks good on it except when I realized that the body plugs that go inside the car from the harness are cut! the harness and plugs are not cut and are fine that go into the ecu. does anyone know which wire colors match up to the sc300 body plugs?? Any help is appreciated.
Thanks
[/IMG]
Old 01-12-09, 11:50 AM
OneJay
OneJay's Avatar
I think the wires from the SC's body plugs are all the same color as the ones from the Soarer. If you have the time, you can probably use the body plugs from your car. Don't forget to extend them though!
Old 01-12-09, 12:21 PM
sunrisetrd
sunrisetrd's Avatar
Thanks alot, I will do
Old 01-12-09, 01:22 PM
CCC-TT
CCC-TT's Avatar
As long as the ECU plugs arent cut, you're good to go. Just be prepared to spend some time getting it all wired correctly, I suggest starting and finishing one plug at a time so you dont end up mixingup wires.
Old 01-12-09, 02:46 PM
sunrisetrd
sunrisetrd's Avatar
Thats what I started to do, thanks for the advice
Old 01-15-09, 02:38 PM
sunrisetrd
sunrisetrd's Avatar
I seem to be running into a problem. It looks like the 1jz has more wires than those sc300 interior body plugs.
Any suggestions?
Old 01-15-09, 03:15 PM
sunrisetrd
sunrisetrd's Avatar
I figured it out, I was missing a plug. But I have noticed that not all the colors seem to match up. I am left with a few odds and ends. I have a white wire and no other white to match it up to, same with a pink wire and a few others.
carter628
08-11-14 07:42 PM
6SOARER
SC- 1st Gen (1992-2000)
12
09-05-11 02:37 PM
6SOARER
01-28-11 12:29 PM
sleeperSC
05-22-08 08:37 PM
thaimonkee
06-10-07 09:51 AM
Quick Reply: 1jz swap problem...
