2JZGTE water pump in an SC300
Iv ordered a water pump, but the part number is 16100-49846
This is apparently for the 2JZGTE. Will it work for the 2JZGE too (SC300 motor) or will I run into problems? Non turbo one is 160049837
Are you putting in a 2JZGTE water pump though. Im not sure if its a direct fit, and what to do with the turbo hose. When I gave Toyota a call, they said taht the GTE water pump wouldnt fit the -GE
Registered User
In case someone also comes looking, it will fit the 1JZ-GTE also. The front is whats really important anyways, that is where the impeller is housed. When I changed mine I noticed the old one had a plastic impeller and the new 2JZ-GTE had a metal one. Much better.
Allright, so it would be quite easy to use the old housing on the turbo water pump? If I jsut use the turbo pump, and put a cap on the turbo outlet, wont the water pressure force it out?
1jzgte603
SC- 1st Gen (1992-2000)
06-16-11 06:45 PM
