Timing Belt
Ive heard different opinions on having the timing belt changed. Someone at Lexus said that if it breaks the car will be fine and others have said the damage will be catastrophic. Any opinions or people with experience. Thanks
moved to engine section
Ninja Edit
Book says GE & GTE in stock form (non VVTI) are NON interferance.
Meaning no valve damage in normal circumstances if the belt
kicks off.
Now if you do a 6 grand holeshot & break it. All bets are off
due to valve float.
Ninja Edit
kicks off.
due to valve float.
1JZ Single SC400
These guys are absolutely correct. Depends on the year of your car. If you have the non VV-TI motor, it will be fine. Let me know if you need the link, if you are doing yourself. I will send it to you.
my2jz
05-07-10 10:42 AM
ckasper
20
06-08-08 08:27 AM
