SC4 Throttle Plate cleaning.
I knew it was in dire need of carbon removal, so today I decided to get it done.
Underhood
When I got the air intake ducting off all I could see inside was black. The Throttle Plate was caked in carbon. The picture I took did not show anything.
This is after the first spray into the throttle body. Notice the huge amount of carbon lossening up.
Mid way - you can start to see that the throttle plate is brass colored, not carbon black.
After cleaning - wow the throttle plate is actually brass colored.
The aftermath of towels.
Underhood
nice and clean.i did that but on a 2jz.but i tied the throttle plate opened,i also bought a long bristle brush from the dollar store and sprayed it with the specified cleaner and brushed away i then wrapped the brush with a clean cloth and cleaned all the crap out it came out pretty good without having to take the throttle body apart.but check engine light came on for a little bit it went out later,i think it was the o2 sensor picking up some crud that got through the system.but it went out shortly after which was a good thing because i had just replaced them all
This can make your idle smother - mine was not really all that rough before, but glass smooth after.
It also will improve your throttle response due to removing carbon deposits that may keep the throttle plate from moving smoothly. - this I did have some and in the 5 miles I drove since finishing, the car does have a smoother throttle response.
a suggestion: that buildup is mostly due to crankcase vapors building up on the back side of the throttle. A normal occurrence, but when i recommend a throttle clean at work i always recommend a PCV valve to go with it. and extra couple bucks and it's cake to put in. just my .02
