My 1jzgte swap thread pic heavy!
Old 03-14-09, 04:03 PM
  #166
OneJay
OneJay's Avatar
Yay!!! Congrats man! The exhaust sounds pretty nice.
Old 03-21-09, 05:15 PM
  #167
RyanV
RyanV's Avatar
Been having a problem with my TT brakes ever since installing them.
I rebuilt the stock master, and it made no difference. Still had alot of dead space in the pedal travel before it caught pressure towards the floorboard(yes I bled etc...new bleeders)
I tried a TT brake master, surely that would fix it...nope!! Same thing.
I tried a TT brake booster, but it's different. I'm wondering now if I can shim it with washers? Shouldnt hurt anything right?
TT booster on the left. The rear shaft is longer.
This is how you bleed the master while it's in the car.
http://img.villagephotos.com/p/2003-...2/IMGP2433.JPG
Old 03-21-09, 07:18 PM
  #168
YeA 2jZ
YeA 2jZ's Avatar
so the TT master cylinder and booster both bolt up ?? I heard you should try some SS lines to help with pedal feel. Love you thread man
Old 03-21-09, 08:04 PM
  #169
RyanV
RyanV's Avatar
The TT booster does bolt up, but look how much longer the shaft is coming out of the booster on the left. That connects to the brake pedal bracket, and it just doesn't fit. If the booster had a 1" thick spacer between it and the firewall this would work out much better.
Old 03-21-09, 09:21 PM
  #170
YeA 2jZ
YeA 2jZ's Avatar
O i C....hmm mabey like a plate type spacer would work best rather than just individual washers, just a thought
Old 03-22-09, 06:37 AM
  #171
RyanV
RyanV's Avatar
Yea, your correct. Washers would create a gap that would let engine noise into the cabin.
Old 03-24-09, 09:56 PM
  #172
RyanV
RyanV's Avatar
I ordered a SC300 brake booster from Aliga. I believe mine is defective as the front rod has in/out play, and it should be tight. <--EDIT this is wrong, the sc300 front shaft does have in and out play, but only a little.
EDIT- the replacement had a little play in the shaft as well, so this is probably normal.
I just bought this too!
JDM Supra TT 3.76 Torsen/LSD differential. The Ateam couldn't build a better drivetrain! Even has the TT drive axles all with 50k miles on it.
I actually couldn't tell if this was the torsen/lsd or not at first, until I found Blizzys' thread where he bought a brand new LSD, and it looked just like the unit in this differential. I guess there are a couple different stock Supra torsen/lsd's, and the other one I've seen has a shinier metal housing, and it also has an open spot in it where you can clearly see the helical gears.
Also, there's another rear end people like using that has a 4.50 ring gear, and it is much thicker than this 3.76 ring gear(the big round gear on the left side, if you don't know what a ring gear is). The 4.5 rear end would be an ideal drag rear end.
My opinion is that the Sc300 stock 4.08 rear end coupled with the R154 and 1jz, is only ideal from standing starts. On the highway, the RPMs are up too high, and kills the Sc300 smooth cruising characteristics.
Old 03-25-09, 01:01 AM
  #173
wanganstyl
wanganstyl's Avatar
nice score. big thumbs up to you and your progress!
Old 03-25-09, 07:57 AM
  #174
RyanV
RyanV's Avatar
Thanks alot!
Old 03-25-09, 10:00 AM
  #175
ICONYQ
ICONYQ's Avatar
so pretty...I need one!!!! Nice score man. It will be nice to drive again!
Old 03-25-09, 10:15 AM
  #176
AD_SC3
AD_SC3's Avatar
Well I don't know how I'm going to make it happen but I'm going 1J. Thanks for the good thread
Old 03-25-09, 10:16 AM
  #177
RyanV
RyanV's Avatar
Your not kidding..
Now I need to either cut my fender lips down myself or find someone else to do it for me so I can drop this sucker on the Supra suspension.
Old 03-25-09, 10:19 AM
  #178
RyanV
RyanV's Avatar
The easiest way to do it would be to find an early engine set of you have a 92-94 sc300 or a latemodel Soarer engine set of you have a 95-97 Sc300.
The way you can tell the difference is the crankcase ventilation tube coming off the turbo side of the valvecover.
Old 04-06-09, 01:46 PM
  #179
wanganstyl
wanganstyl's Avatar
how low are you going to drop it? stock tt sus is not that low
Old 04-07-09, 07:41 PM
  #180
RyanV
RyanV's Avatar
Main thing is that my rear tires 285/35/18 rub the fender lips sometimes with the stock suspension.
Chris at BoostLogic was telling me that rolling the Supra/Sc300 fenders isn't an ideal situation because the fender lips are thick and don't bend easily. He's actually seen the rear quarters bend/crease, so instead he cuts the lips out cleanly.
I was thinking about trying my Dremel to see how long it'd take to cut the lips off.
Quick Reply: My 1jzgte swap thread pic heavy!
