My 1jzgte swap thread pic heavy!
Old 07-14-09, 05:16 PM
  #226
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Any updates on this buildup... Pretty impressive if you ask me..
Old 07-14-09, 07:59 PM
  #227
RyanV
RyanV's Avatar
Thanks, I do have a couple updates.
I found the major A/C freon leak! The small line that runs under the radiator is held on by a bracket. If that bracket get rust grime on it, and corrodes, it can crack the small line. Mine is cracked all the way around.
The line is ruined. The dealer charges $5oo for both lines & the pressure sensor together as a special order package only, apparently.
The car is at the shop Thursday to get this replaced and hopefully charged back up. Gotta have A/C, it's been 100-106 here for the last several weeks now.
I noticed that there's plenty of room for an electric fan in front of the condenser. I just have to figure out how to mount one up.
I found a boost controller that I liked. AEM TruBoost. I haven't installed it yet because getting to the backside of the rear turbo is almost impossible.
I got an oil cooler kit to try out as well.
Old 07-16-09, 05:42 PM
  #228
RyanV
RyanV's Avatar
The A/C line was fixed, and the car is blowing real cold again! Like 50degrees!!
It's weird because the car seems to run slightly cooler on the temp gauge now with the A/C on, even in 102 sun on the way home. I'm still going to get a small elect fan hooked up.
Old 07-17-09, 12:03 AM
  #229
BigManne
BigManne's Avatar
yea i gave up on the rear turbo waste gate line. i still dont know when im going to try again
Old 07-17-09, 09:18 PM
  #230
meangreen1
meangreen1's Avatar
So have you put it on the dyno yet???
Old 07-18-09, 08:42 AM
  #231
RyanV
RyanV's Avatar
No, I haven't. I just haven't had the time yet and weekdays are out.
My plan was
dyno at 10psi, 13.5psi then tune it with emanage/440s at 17psi.
something like that...
Old 07-26-09, 07:30 AM
  #232
howat
howat's Avatar
Hey Ryan, just read all 16 pages. Looking good and very informative. Thanks for sharing!!
Old 07-29-09, 05:39 AM
  #233
99SC42
99SC42's Avatar
Ryan is the ABD light on? I just finish another 1JZ swap and this is second one with ABS light on!!! The first one was 92SC3 and the last one 95SC3, i am confuse right now thanks
Old 07-29-09, 06:38 AM
  #234
RyanV
RyanV's Avatar
Hey thanks, that means alot.
Hey Omar, my abs light is not on.
Have you checked for engine trouble codes?
Old 07-29-09, 08:50 AM
  #235
99SC42
99SC42's Avatar
Hey Ryan i had the same issues when i han this engine in my 92 SC ,so now i swapped that engine into my 95 SC and the ABS light is still on,
ON the 95 when you look on the botton of the Glove box there is a module with i think it's the ABS module and there is no plug going into that module since i am using the 1JZ GTE harness made for a 92SC
Old 10-16-09, 10:07 PM
  #236
Superjatt
Superjatt's Avatar
WOW.. finally got to page 16'
soo impressed man
im getting my 1j soon so ill be pming and botherin you =]
Old 10-22-09, 07:58 PM
  #237
RyanV
RyanV's Avatar
It's been awhile!
So the picture hosting company I've been using for over 5 years is finally having major issues...so that's why the pics aren't working right now!
Bummer cause I want to show you guys what I've been doing in my copious amount of free time...
To sum it up WITHOUT pics...
1. Full leatherseats.com interior set installed
2. Emanage Ultimate up and running finally!
3. Supra TT spare ftw!
4. trunk shocks
Got some other things to install...door panels, door brackets
If these folks don't get my pics up soon....I'll have to find someone else, and reupload all the pics so the thread will have the pictures...for CL..I'd do it! It's worth it...
Ryan
Old 10-22-09, 08:31 PM
  #238
meangreen1
meangreen1's Avatar
What color of seats did you do?
Old 10-22-09, 09:19 PM
  #239
RyanV
RyanV's Avatar
I did tan seats. Damn they look good too..
Old 10-23-09, 05:43 PM
  #240
RyanV
RyanV's Avatar
Hosting provider came back online today, here's a few pictures of the seats.
Quick Reply: My 1jzgte swap thread pic heavy!
