My 1jzgte swap thread pic heavy!
#301
Ryan the 3.92 works great that what i had in my SC, the 3.26 was too low for the street.
7hrs ryan haha i know you can do better than that, so are you gonna pull the motor out of the Supra to do all the maintenance?
#303
Your right, I probably could pull the trans and get it install in 7hrs.
Far as the Supra- I'm not sure yet, lol.
#306
#307
*the OEM bolts come with a red loctie sealer type stuff on them so that oil doesn't work it's way past the bolt.
If you use ARP, you will need to use something to block the oil like FIPG black on the threads or blue loctite.
Basically the flywheel boltholes are drilled through the crank and oil from the pan can slosh right into the holes.
Even though I used FIPG on the ARPs I took out, I noticed that oil was very slightly seeping from one of the bolts. Just a trickle.
#308
The OEM flywheel bolts have a bunch of this red thread sealer stuff on them to prevent oil from the pan working it's way through the threads.
Even though I used FIPG black on the ARP flywheel I took out, I noticed a trickle of oil coming through one of the bolts.
#311
I've been wanting to record some MPH/RPM numbers.
Once I install the 3.92 diff this weekend I'll make note of the new numbers.
The W58/R154 will be almost identical for these numbers so it doesn't matter which trans your running.
Basically what I'm saying here is that the W58 or R154 with the 4.08 rear gears are a tad too short for daily driving when you have 300HP or more, IMO-
EDIT:mph numbers slightly changed after using GPS to verify
These numbers are with the W58/4.08 differential combo
comfortable shift point..
2nd gear 38mph@3100rpm
3rd gear 45mpg @3100rpm
4th gear 55mph@3100rpm
Cruising gear and rpm's at different cruising speeds
5th gear-
63mph@2700rpm
68mph@2900rpm
73mph@3100rpm(this kills fuel economy, it would be better to be turning around 2500rpm here in 5th)
When I had the 3.26 diff installed it was completely the opposite almost to the point of being rediculous. The gears were far too tall and the car was a dog off the line. 3rd and 4th weren't bad although 5th was only good for highway cruising, but downshifts needed to do any passing or uphill driving.
5th gear-
63mph@2700rpm
68mph@2900rpm
Last edited by RyanV; 04-09-11 at 11:23 AM. Reason: verifed mph with gps numbers changed
#312
I took some video while I was swapping out the R154 for the W58.
My wife bought me this HD camcorder for Xmas so I needed to use it for something.
#1 1995 1JZ Sc300 manual transmission removal
http://www.youtube.com/watch?v=f_BP5YAA-bQ
#2 1JZ 1995 Lexus Sc300 differential removal
http://www.youtube.com/watch?v=bNtnv6vHMP0
#3 1JZ 1995 Lexus Sc300 differential removal
http://www.youtube.com/watch?v=geEDRHqhy34
#4 1995 Lexus Sc300 differential removal
http://www.youtube.com/watch?v=MBYKQpp5Qcg
#5 1995 Lexus Sc300 driveshaft removal
http://www.youtube.com/watch?v=CjCadiDaNbw
#6 1995 Lexus Sc300 manual transmission removal
http://www.youtube.com/watch?v=QnZC86QR0a8
#7 1995 Lexus Sc300 manual transmission removal
http://www.youtube.com/watch?v=zeaj7FggNjQ
#8 1995 Lexus Sc300 manual transmission removal
http://www.youtube.com/watch?v=h_TplgWC_2Y
#9 1995 Lexus Sc300 clutch installation
http://www.youtube.com/watch?v=kamN4NmqFMw
#10 1995 Lexus Sc300 W58 throwout bearing install information
http://www.youtube.com/watch?v=TfJksmgtSMk
#11 1995 Lexus Sc300 manual transmission installation
http://www.youtube.com/watch?v=UMZBqE_sXEY
#12 1995 Lexus Sc300 manual transmission installation
http://www.youtube.com/watch?v=6rsynz8y2DA
#313
5th gear-
63mph@2700rpm
68mph@2900rpm
5th gear-
63mph@2700rpm
68mph@2900rpm
