I couldn't figure out how to route the 2jzgte throttle cable either.
you need a mk4 2jzgte throttle cable. someone wrote previously that the 87-91, pretty sure, Camry throttle cable works as well. you can go to the yard and take one off a camry, paying only a few bucks, or buy one from the dealer.
I just couldn't tell where the set bolt was supposed to sit? I was thinking it sits on the lower bracket, then the actual cable kinda goes up at an angle to the butterfly? Is that right?
what about that grey ground wire? I think it connected to the actual 2jzge block before, but I don't see anywhere on the 1jz block to connect it, that's why I used that spot on the intake??
you need a mk4 2jzgte throttle cable. someone wrote previously that the 94-96 4cyl, pretty sure, Camry throttle cable works as well. you can go to the yard and take one off a camry, paying only a few bucks, or buy one from the dealer.
fixed!
Thats the one I have. Its a little long, but works perfect.
The A/C condenser showed up today, but the line connections are different, because it's from a Soarer(they are different diameter than us spec, just like the a/c compressor connections),...so there's some wasted time/money.
radiator hoses actually shipped on Thursday.
I'm a little agg'd right now.
and I did a chargeback, because I believe the HKS BOV that I bought was a knockoff in a real HKS box...
All that aside, I think I may start it tomorrow to make sure it actually runs.
You should reconsider that bracket that you made to hold hte intercooler. Try getting just a one piece metal bracket and bending it....theres less things that can get loose and will cause you less problems down the road. Other than that, looks good!
Well the piping itself looks fine how it is. I ran mine like that for like six months and it was just fine. I only changed mine because it looks less cluttered now.
