Tach only reads half of real engine rpm?
Old 01-31-09, 09:23 PM
defrag010
defrag010's Avatar
Default Tach only reads half of real engine rpm?
I finally got an axle in the new SC400 I bought, and was driving it around today. I noticed that the engine seemed alot louder for the rpm that the tach said, and after paying attention to it while driving, noticed that the tach only showed half of the real rpm!
Is this a common problem? After research, I found out that the car has 2 coils.. so could one coil have something wrong with it where it isn't registering on the tach (thus, showing only half the real rpm) ?
Old 02-01-09, 05:54 AM
RedPhoenix
RedPhoenix's Avatar
From my experience...
Driver Coil bad + Passenger Coil good = RPM = 0 @ 2000 or less. The tach would rev up to about 2k and then drop to 0 with a bad coil.
Now... I had an SC300 gauge cluster in my car when I was getting mine redone. The RPM's are about half of what they should be. Probably about 2/3 to be exact. Has this car been modded in anyway? If the car shifts around 4k @ WOT, then this may be the case.
If its less, then its probably something to do with ignition.
Old 02-01-09, 08:38 AM
defrag010
defrag010's Avatar
Yeah, the car shifts at about 3500-4000 rpm. I have no history on the car, but apparently some tuner owned it because it has a suspension on it and it had TT supra wheels on it before I bought it.
Old 02-01-09, 01:21 PM
RedPhoenix
RedPhoenix's Avatar
I would be afraid to say that it may be a different cluster... I am not sure how to check though. But that was my problem with my borrowed cluster... I would cruise @ like 1000-1500 rpms.
Old 02-02-09, 04:55 AM
tavarish
tavarish's Avatar
Swap out the tach. When I used an SC400 tach on my sc300, the rpms would be crazy high, but went down when i swapped it for my spare sc300 one.
Old 03-05-09, 12:23 AM
cartmill
cartmill's Avatar
holy crap this is exactly what my car is doing...
so you're saying the previous owner may have swapped in a sc300 gauge cluster? that would make perfect sense because the 6cyl tach would get 2/3rds of the ign signal that the 8cyl tach wants. my engine soulds like it's revving to the moon, but the tach says it's hitting the rev limiter at 4200rpms.
Old 03-05-09, 06:46 AM
defrag010
defrag010's Avatar
yeah, the cluster in my car has an amber backlighting and no gear indicator lights so It's from a 300.
iceblast
ES - 5th Gen (2007-2012)
03-18-14 11:42 AM
greyBLITZ
07-13-11 09:54 AM
Carib
17
03-11-09 03:48 AM
lsnick
12-05-08 11:34 PM
lexusxrcr
15
08-23-07 08:29 PM
Quick Reply: Tach only reads half of real engine rpm?
