Should I get a 1JZ or a 1JZ VVT-i?
Old 02-04-09, 09:05 AM
DRFTSC400
DRFTSC400's Avatar
Default Should I get a 1JZ or a 1JZ VVT-i?
there's a shop down the street from my house and they have both these engines. they want $1500 for either or i believe. What do you guys think? What are the pro's and con's between these two engines?
Old 02-04-09, 09:26 AM
StiCk3
StiCk3's Avatar
The 1JZ-GTE (non VVT-i) swap has been done a ton of times so there is a lot more experience and info about it. There aren't many 1JZ VVT-i SC3s that i know of, some one here on CL is currently trying to complete the swap. The advantage of the VVT-i is that it is a single turbo (as opposed to twins on non VVT-i) and has better low end response. VVT-i also provides better flow under full load conditions. The only downside is parts compatability is still unknown for the VVT-i as very few people have tried it and posted information about the swap. If this is your first engine swap go with the non-vvti as the swap is relativley simple, parts are plentiful and you'll have more options for power upgrades down the road.
Old 02-04-09, 09:32 AM
DRFTSC400
DRFTSC400's Avatar
yeah i noticed it had only 1 turbo when I saw it. Well that sounds reasonable... another thing on my head is that I have an sc400. I've heard people go through a hassle when they do the swap on a 400 against the 300. I'm thinking of maybe buying an sc300 to do the swap on that one and keep my 400 as a 400 lol.
Old 02-04-09, 10:45 AM
ihiryu
ihiryu's Avatar
We swap sc400 pretty often. It's not that bad, but you'll spend a bit more money on extra things.
Old 02-06-09, 01:41 AM
DrLex
DrLex's Avatar
Do you plan to modify it for over 400rwhp or do you just want a clean stockish upgrade?
If you are going for big power, standard 1JZ.
If you just want more low end power and a stockish feel, go VVTi (will cost slightly extra to install).
Old 02-06-09, 03:35 AM
dinhnerz
dinhnerz's Avatar
Go with the non VVTI, send the harness out with the stock v8 harness and the 1jzgte harness to get it wire up to your car.
Should be a couple days of work. There is alot of information on the 1jzgte swap, Search thru the forum you'll find tons of information on the topic.
Old 02-06-09, 08:40 AM
soarer13oy
soarer13oy's Avatar
Where exactly do you live? id like a motor set for $1500
Old 02-06-09, 01:02 PM
Anthony85
Anthony85's Avatar
When Swapping a 1j into a 400 you will basically need quite a few sc300 parts like the drive shaft, 2j engine mounts, i think power steering lines, etc. Its almost like your converting it to a 300 first so the swap will go through easier.
Old 02-06-09, 01:27 PM
Slow_Sc3
Slow_Sc3's Avatar
also the sc400 dash wiring is a little different then the sc300
bobwamotsw
04-28-18 08:49 AM
esc300
SC- 1st Gen (1992-2000)
09-01-14 08:47 PM
lex1220
12-15-11 07:38 AM
t70 supra
05-10-10 08:49 AM
FormosaSC
04-11-07 08:16 AM
Quick Reply: Should I get a 1JZ or a 1JZ VVT-i?
