SC300- full tank to dead dry average
like everyone said, do your maintenance..otherwise you will be getting great mpg when your walking to and fro..
i average between 19 and 21 city, 25 to 26 hwy...but somedays depending on how i'm driving, i might get 15mpg...need to lay off the go-pedal if you know what i mean
ok , so far after changing out 2005 oil, filter, tranny fluid, filled up my sub-frame, diff bushing with poly urethane, spark plugs, and alignment..still with the Kaaz 2way differential.
i ve been getting 360-375 from full to dead dry.
thats a slight improvement, over 310-360 miles.
i ll change out the belt and pulley bearings, and from experience, that should bump it up a little better. i ll keep posted.
from full to right when the gas light turns on i get at least 400 with regular driving. mix of city and highway.
when i bought the car in 2006 i picked it up in florida and drove it back i was averaging 500 on 18-19 gallons.
that was mostly on cruise control and at about 75-90mph.
the way i calculated accurate mileage was drive on a full tank and zero out the trip meter. when the gas light just turns on i go and gas up. the mileage you rack up on the trip meter divided by the number of gallons you put in to the tank is you average gas mileage.
LuxuryGS3
09-02-10 02:31 PM
