What do you think of this turbo?
Hey, what do you guys think of this turbo? Im thinking about FI, which turbo do you think is the best for my 1997 sc300?
http://www.suprastore.com/tosutucokit1.html
That is the XSPower turbokit found on www.clubna-t.com.
http://forum.clubna-t.com/showthread.php?t=2037
It's actually about 50 bucks cheaper here.
It's not a bad kit, but some people have had issues with the quality of the turbo. Overall not bad bang for the buck.
I disagree..not all of us want 5 bajillion horsepower..when i go turbo i just want a small turbo to make just over 350 horsepower and build my automatic tranny to hold it..i don't want to run 9 second quarter miles..just be able to keep up with today's standard of cars.
im with dirtysc3 and tavarish. thats the best kit ive ever seen for the buck honestly. its only a few adjustments and you can get upwards from 350whp which sounds dayumm good. thank you theory5150, im now saving for this kit. one question, does an automatic perform better with the turbo over standard? i thought it was vice versa. also, is 80k to many miles to safely handle this kit?
both motors are amazing compared to the n/a motors
Gotham racing in the dfw, tx is running a stock bottom end 2jzge with a gte head making well into the 1000whp range, the 2jzge motor can handle 800whp just fine with swapping out the hg for the tt or a thicker one. I been reading on going na-t and that's my choice be different everybody swap out for the 1jz or 2jzgte bro. The crank and rods are the same as the gte, the pistons are slightly different but once the thicker hg go on your fine.
Any mechanic's shop can perform a compression test so that's the first thing that needs to be done before you start finalizing plans for na-t. Also when putting you turbo setup together make sure you take into account all the little extra tidbits needed like fuel managment, wideband 02, gauges, boost control (optional if you just want to run it off the wastegate) etc. Then after that add about and extra $1500 just in case things go the wrong direction. Good luck!
ya but 2jzgte motors are pretty cheap, and its got alot of bang for its buck... You drop the motor in your car slap an intercooler kit and play with the boost. And if you want more you have the proper motor to do it! Thats what hes saying. I find the capabilitys of the stock i6 in the sc300 i find cant handle much or do much with it. 2jzgte is easy power for your money so is the 1jz.
Both motors are amazing compared to the n/a motors
